Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics > 2.4G JR Radios
2.4G JR Radios JR 2.4 Gigahertz Radios and Technology
Old 04-07-2007, 10:03 PM   #1
inmidair
Default how to bind?
can someone please explain to me how to bind the TX and RX?
im looking at the DX7 manual and the pic shows some kind of switch. ? and i dont understand the 3 way wiring they show.
(DX7, AR6100)
Allen-
"Whether You Think You Can Or You Can't- Either Way You're Right"
inmidair is offline        Reply With Quote
Old 04-07-2007, 11:07 PM   #2
Danal Estes
1) Put bind plug in BAT port on receiver
-or-
Put switch harness in BAT port and put bind plug in other end of harness
2) If using switch, turn it on
If not usin switch, plug battery into any other port
Reciever will have a flashing light. (if 7000, both halves will have flashing)
3) Press and hold bind plug on back of Transmitter; while still holding this button, turn on power switch
4) Within about 3-5 seconds, receiver light will go solid (and if you have servos hooked up, you will suddenly have control) (if 7000, wait for both halves to go solid)
5) Let go of button, turn everything off, remove bind plug.
That's it. One time operation. From then on, TX on first, RX on second, they will "link" and have control in about 2-3 seconds.
A couple of hints:
If for any reason they don't link (and just occasionally they won't because they run a whole bunch of quality checks every startup), just power cycle everything and they'll link up next time.
Remember "model memory"; if you are on the wrong model, they won't link. Switch to correct model, power cycle TX (only) and they'll link.
Startup positions for all servos (and failsafe for throttle) are memorized at bind time. Be sure you have the controls where you want them. For this same reason, if you make MAJOR setup changes, consider re-binding. In particular, in a heli, re-bind after you have your full gyro setup working (so gyro will init properly).
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/JR8717@8V/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote
Old 04-08-2007, 12:32 AM   #3
inmidair
thanks again danal! its bound. now i have to set up the swash, gyro, esc, throttle and pitch curves.
oh boy, im glad i took out the main gear before attempting that!!!
Allen-
