Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 08-20-2011, 04:11 AM   #1
canadien007
Default Xtreme Productions Pro 180 Motor
Hello
I was wondering if it is possible to upgrade to the Xtreme PRO 180 motor on my 120 SR?
I know the the stock motor has a female JST and the PRO 180 has a male. With a little soldering job it should get that taken care of right? Also the pinion is different on the 180 in comparison to the stock motor pinion. How difficult is it to change the pinion gear? Is it even possible to change the pinion gear?
canadien007 is offline        Reply With Quote
Old 08-20-2011, 05:02 AM   #2
OnThaEdge
Why would you bother when Xtreme Productions has a motor specifically for the 120SR
http://www.xtreme-production.com/xtr...mart&Itemid=31
There's a lengthy discussion on it here
http://www.helifreak.com/showthread.php?t=326401
OnThaEdge is offline        Reply With Quote
Old 08-20-2011, 01:22 PM   #3
Dontfakelife
Default Stay with the specific one...
I think that motor needs 7.4v to run - for some reason I think that sticks in my mind... pretty sure I saw that in a forum in regards to the 180 motor for the cx used on the 120sr.
I would def. say go for the specific one for the 120sr... and there is one single post that would convince me (see below)
Originally Posted by Thunder1 View Post
Hi all
I tested my two motors today
Both are new
& i broke them both in first (AA battery method)
I used fresh Tiger batteries (3.7v, 600mah 15c)
Stock SR120 motor - 211grams to -215grms
Xtreme SR120 motor - 228grams to -232grams
Stock SR120 motor weight 36grams
Xtreme SR120 motor weight 32grams with the long power wires
I found the Xtreme SR120 motor to pick up faster & is quieter/smoother,
in flight it has more lift & is faster than stock even though the numbers are similar
To get the readings i just taped my Heli to my kitchen scales then zeroed them, To get the negative reading
i tried it with some small scales first, but it took off with them
hope this helps
Blade 120SR - RKH Swash & Hub, CF Flybar, Align skids | Blade mSR | Blade SR - CF Boom | Phoenix | Realflight
Dontfakelife is offline        Reply With Quote
Old 08-22-2011, 06:36 PM   #4
canadien007
Thanks both of you
