Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 08-21-2011, 06:41 PM   #1
Phreak Out
Default Assistance Setting Up Swash Plate Please?
I have a DX7 and I'm making an honest effort to figure out the preliminary setup for the swash plate with a Thunder Tiger Mini Titan V2. This heli uses main grip control arms on leading edge of blades (image below).
Code:
REVERSING MENU
___THR___AIL___ELE___RUD___GEA___PIT___AUX___
____1_____2_____3_____4_____5_____6_____7___
____ _____X_____ _____X_____ _____ _____ ___
____X_____ _____X_____ _____X_____X_____X___
SWASH MIX MENU
AIL     +50
ELE     +50
PIT     +50
With these settings, everything seems to work properly --except-- the collective pitch - the swash plate moves up when the stick moves up.
The cyclic seems to be good - looking at the heli from behind, stick right = swash tilts right, and stick up = swash tilting up in back, down in front.
I've tried everything I know to reverse the cyclic while keeping the swash "as is" but I'm clueless - have no idea how to fix this. I tried swapping the values in the swash mix menu - first I used -50 for ELEV, didn't work, then I put that back to +50 and tried -50 for both AILE and PIT - nope.
Any help will be most appreciated.
Name:	po main grip 01.jpg
The best performance upgrade is practice
Do it safely, do it often, and enjoy it. AMA #20703
Phreak Out is offline        Reply With Quote
Old 08-21-2011, 06:48 PM   #2
DominicD
The Capi
Changing the polarity/sign of the pitch percentage in the swash menu HAS to work.
DominicD is offline        Reply With Quote
Old 08-21-2011, 06:57 PM   #3
Phreak Out
I'll try it again . . . I hold my own among the most intellectually challenged . . .
Old 08-21-2011, 08:38 PM   #4
Phreak Out
YESSSS!!!
Mega-thanks!!!
Old 08-22-2011, 02:09 PM   #5
twiggums
Haha i had the exact same problem when i was setting my heli up! And then after messing around with everything else a light finally came on that said "duh change the pitch curve".
twiggums is offline        Reply With Quote
Old 08-22-2011, 03:45 PM   #6
DominicD
The Capi
You shouldn't be changing the pitch curve.
Old 08-22-2011, 08:45 PM   #7
twiggums
wouldn't changing the pitch curve essentially do the same thing? (ie instead of 0,25,50,75,100 setting to 100,75,50,25,0 assuming 50 is 0 pitch).
edit: i do understand what you're saying and that does make more sense. I"m still a bit of a noob and had the same problem. i just changed my pitch curve and it solved the problem, however changing the polarity of the swash mix makes alot more sense now that i read over this again.
Old 08-22-2011, 09:20 PM   #8
DominicD
The Capi
Just do it properly
Old 08-22-2011, 09:28 PM   #9
twiggums
Just do it properly
lol i agree! and will be changing mine.
however it would have the same effect rite? lol sorry just trying to make sure i have an understanding of what is being accomplished by adjusting swash numbers. It'll just reverse the movement direction of the collective the same way it would by inverting the pitch curve correct? (assuming you just change polarity, not the actual number value)
Old 08-22-2011, 09:30 PM   #10
DominicD
The Capi
Yes and no, some radios treat low stick different than high stick, and reversing the PC will negate that programming.
Old 08-25-2011, 08:03 PM   #11
Phreak Out
I think I must have done something wrong like I have something backwards?
Code:
Left stick high   =  +  7.5 degrees
Left stick middle =  -  1.8 degrees
Left stick low    =  - 12   degrees
Can anyone point me in the right direction?
Old 08-25-2011, 08:16 PM   #12
DominicD
The Capi
Watch the CCPM vids.
http://helifreak.com/showpost.php?p=373271&postcount=1
Old 08-25-2011, 09:06 PM   #13
newbheliusr
Yep, lengthen your pitch links. Probably 2 full turns on each would be about right.
newbheliusr is offline        Reply With Quote
Old 08-25-2011, 11:11 PM   #14
Phreak Out
Old 08-27-2011, 11:01 AM   #15
Phreak Out
Update --> I shortened each of the two links by two full turns & now I have zero pitch at mid stick and ~+/- 10.5 degrees at high and low stick.
I will begin looking at pitch & throttle curves next.
I reckon when I finish the radio & head setup, then tidy up the wiring and balance my blades, then it will be time to attach the training gear and head to the flying field - woo hoo!
Old 08-27-2011, 11:06 AM   #16
Inverse
Do you have a swash levelling tool?
If not, get one on order now, they are vital to a properly set up heli and for the few bucks they cost, they are well worth it.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 08-27-2011, 11:18 AM   #17
Phreak Out
Yes, thanks - this heli came with a plastic one.
Old 08-27-2011, 01:09 PM   #18
Phreak Out
I have never gotten the heli this close to being "done" before.
I just finished programming the throttle and pitch curves.
Question #1 --> what's the typical position of the throttle hold switch: flipping the switch away deactivates or activates throttle hold? I believe throttle hold is setup properly but I think it might be reversed - I'd like to keep mine like everyone else's, of course.
Question #2 --> As a newbie should I change the Expo settings for the aileron & elevator so the stick input is somewhat less sensitive around center stick? The book I have doesn't list any expo settings.
Old 08-27-2011, 01:51 PM   #19
NCcraig
Throttle hold on my radio is off in the "0" position and on in the "1" position. I thinks that is the way most are.
I'm still a newbie and I have around 20% expo on Aileron and Elevator. It's really what your comfortable with so experiment with it and figure out what is good for you.
Craig
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
DX9, AMA# 966513.
NCcraig is offline        Reply With Quote
Old 08-27-2011, 02:28 PM   #20
j32driver
I'm going to second what NCCraig said about the expo. I've flown it with zero expo. I found the heli to be extremely agile around center stick. I've updated to 20% expo on aileron, elevator, and rudder... and I find those settings much more liveable as a newb.
j32driver is offline        Reply With Quote
