Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics
JR and Spektrum Radios and Electronics JR and Spektrum Radios, Gyros, Servos, Etc.
Old 08-21-2011, 09:46 PM   #1
uluaz
Default JR DS8717 at 6.8 Volts
Does the DS8717 servos handle 6.8 volts ok? These are the regular 8717's not the "HV" ones. Just got a Reactor X2 regulator and want to run these servos at 6.8 volts.
Trex 600CF
Trex 600N Pro
uluaz is offline        Reply With Quote
Old 08-27-2011, 06:24 AM   #2
Pinecone
Yes, they are rated to run off 4cell and 5 celll (nominally 4.8 and 6 volt) power supplies.
A 5 call pack is around 7 volts off the charger,
And many people are running them off a straight 2S lipo pack without issues (7.4 volt nominal, 8.2 volts fully charged).
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 08-27-2011, 07:55 PM   #3
aerocal
6.8 volts should not be a problem.What may be a problem is that as you increase the voltage the current use also increases.You will want to make sure that the regulator can supply the nessesary current/amps at whatever voltage you are using.
P.S. As a reminder.If your running 8717s at the higher limits of the voltage range it is IMHO nessesary to use more than one servo type connector if that is how you are getting the power into the Rx bus.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote
Old 09-11-2011, 09:56 PM   #4
Scottyb410
Originally Posted by aerocal View Post
6.8 volts should not be a problem.What may be a problem is that as you increase the voltage the current use also increases..
With respect:
As you increase the voltage, the current will decrease proportionality.
Ohms law
Cheers
Scotty
Goblin 700 KDE700XF-535, Vbar NEO 6.1, BL9180 9188, Kosmik Cool 160 Goblin 630 HK 4525-520, Vbar NEO 6.1, BL9180 9188, Jive Pro 120 Goblin 380 Xnova 3215-930, Vbar NEO 6.1, DS-3001HV, DS5005HV, Koby 90
Scottyb410 is offline        Reply With Quote
Old 09-12-2011, 03:28 AM   #5
aerocal
Originally Posted by Scottyb410 View Post
With respect:
Ohms law
Cheers
Scotty
Thats what you would normally expect.As you increase voltage the amperage should decrease proportionally.The actual current in watts should remain somewhat equal.In actual practice this is not always true with servos.
HELIFREAK !!!
Old 09-12-2011, 07:09 AM   #6
BarracudaHockey
Ohms law assums a constant load.
Andy
AMA 77227
Jacksonville FL
http://www.jaxrc.com
BarracudaHockey is offline        Reply With Quote
Old 09-12-2011, 06:56 PM   #7
Pinecone
Higher voltage means higher speed of the motor. This means an increased load, so current may go up.
Terry
Old 09-13-2011, 03:41 PM   #8
Scottyb410
Default Amp
Yes interesting point.
I am going to test this in our lab. If you think of it, since the voltage rises, efficiency would rise as well, in turn, current may decrease.
This is an interesting exercise. I will let you know the results.
Cheers.
Scotty
BTW
uluaz, if you feel your thread is being hi-jacked - just let me know and I will start a new one.
S.
Old 06-06-2012, 10:22 AM   #9
Madryan
Default Efficiency
The principle is that the raised voltage uses less current to produce the same power output as follows.
Example: 6 Volt servo drawing 3 Amps and producing 18 Watts of power dissipation.
V/I=R
6 Volts / 3 Amps = 2 Ohms and
P=V*I = 18 Watts Power use
now at 8.4 Volts if you want to produce the same same 18 watts power consumption you do this:
18Watts / 8.4Volts = 2.4 Amps
Same power output...higher voltage, less current, less losses, longer lasting battery and better performing servo during flight.
so in a rounded up fashion...30% increase in voltage provides about a 20% reduction in current usage..
Last edited by Madryan; 06-06-2012 at 10:26 AM.. Reason: Just realised how old this thread is HAHA whoops...
Madryan is offline        Reply With Quote
Old 07-27-2014, 06:35 PM   #10
Sowa
Resurrecting an old thread.
I recently felt my DS8717's after a flight and they were too hot to touch. Could this be caused by running 2s LiFe straight for rx power?
Protos 380 - Xnova 2820 - HW60V4 -Brain2
Goblin 570 - 91SRX Tareq - Hatori - Brain2
Goblin 700c - TRM VX300se - TRM - Brain2
Protos 770 Max V2 - Xnova 4535 - HW160V4 - Brain2
Sowa is offline        Reply With Quote
Old 07-27-2014, 06:50 PM   #11
Ah Clem
It very well could be.
I always run mine on 6 volts and they are never warm.
Old 08-10-2014, 01:12 AM   #12
Sowa
I hear reports of others running them at 8v coming down at a normal temp. Felt a flying buddies servo after his flight (ds615) and it was warm, but nothing alarming. After 2min in my heli and the servos are pretty hot.
Old 08-11-2014, 11:08 AM   #13
Ah Clem
Do you have the settings in the FBL unit set correctly for the 8717's?
