Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 08-28-2011, 07:27 PM   #1
freestyledork
Default brushless motor issue
the stock motor on the b450 is binding up on me.. it started squeaking on spool up so I turned it off pulled it out of the case. I noticed with out power the motor was hanging up when I tried to spin it with my hand I couldn't tell if it was the gears or not so I pulled it all the way out. Still binding on me so I took it apart and cleaned it very thoroughly. No more binding. I took it back out flew it once and changed packs and same problem. Now it wont spool at all just skips even at full throttle (only tired for a second) So is my motor bad?
freestyledork is offline        Reply With Quote
Old 08-28-2011, 07:49 PM   #2
FuntanaS
Maybe bad bearings?
FuntanaS is offline        Reply With Quote
Old 08-28-2011, 07:55 PM   #3
freestyledork
yup is there a place to get a replacement?
took it apart again and noticed it was completely bent
Old 08-28-2011, 07:57 PM   #4
FuntanaS
The bearing was bent? Or the shaft?
Old 08-28-2011, 08:13 PM   #5
freestyledork
bearing
Old 08-28-2011, 08:17 PM   #6
FuntanaS
I suppose take the bearings out and measure them. Most bearings are measured in millimeters. They are measured by the outside diameter, inside diameter and the thickness. I know tower hobbies sells bearings. Just find a set of bearings with the same dimensions and you should be alright.
Old 08-28-2011, 08:25 PM   #7
freestyledork
stupid thing broke apart and is in pieces now.. I guess I hit the local hobby store tomorrow
Old 08-28-2011, 08:31 PM   #8
FuntanaS
Any ideas on how it happened?
Old 08-28-2011, 08:45 PM   #9
freestyledork
Nope.... Dirt got in I think. Not to sure
