Old 08-30-2011, 09:20 AM   #1
Stevin
Default DS510 Servos Clicking After I changed the gears???
After a bad autorotation and a tiny blade knick the servos started clicking. I opened it up and found a stripped gear so I changed the gear and looked over the others, all gears are fine but I am still hearing a click when moving the servo. I ahve since flown so it is flying but I am concerned about the clicking noise. Any ideas?
Trex 700L Vbar 5.3pro / Mikado Logo 600SX / Trex 450 pro vbar 5.3pro/ Velocity50 Vbar 5.3pro -still the best 600 class nitro-/Trex 600efl PRO vbar/CC HV80
Stevin is offline        Reply With Quote
Old 08-30-2011, 10:02 AM   #2
flerpie
Identify which servo is clicking.
Unplug it from the rx.
Continue....any other servos clicking?
How many servos click? Just 1?
Sometimes a little piece of gear can get stuck in the grease
inside the servo and then work it's way back into the gear train.
I find it pretty hard to find broken gears if I don't use a 10x mag glass
to look them over.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 08-30-2011, 10:48 AM   #3
acidla
Stevin,
Loosen a little bit the screws that hold the servo case.
Hope this helps.
- Michalis - OXY HELI Team Pilot -
- Logo 700 - Logo 690SX V2 - Logo 550SX -
- Protos 380 - OXY 3+
- VBar Control...let the flying be second nature!
acidla is online now        Reply With Quote
Old 08-30-2011, 03:21 PM   #4
Tangolima600
I'm guessing you already thoroughly inspected the rest of the gears because more likely than not there's another chipped gear in there. Like Flerpie said check for any debris in the grease too.
Trex 550 w/ MicroBeast FBL, Trex 450 w/ MicroBeast FBL, Blade 130x, Dx7s, Phoenix Sim
Tangolima600 is offline        Reply With Quote
Old 08-30-2011, 03:30 PM   #5
helicopter1
Did you clean the servo well? There might still be teeth from the old gear that stripped.
It is very hard to spot them that is why you have to clean it very good, wipe the old grease and replace all the gears that are broke and install new grease.
helicopter1 is offline        Reply With Quote
Old 08-31-2011, 01:22 PM   #6
christopherkriens
I had this happen last week, replaced the gear that was missing teeth, but the servo still clicked. Replaced all the gears and it stopped- never was able to visually identify the bad gear.
christopherkriens is offline        Reply With Quote
Old 08-31-2011, 04:43 PM   #7
Stevin
I kust picked up a pack of metal gears. Can I use the silicone grease for the gears?
