Go Back   HeliFreak > R/C Simulators Support > RealFlight Flight Sim
RealFlight Flight Sim All versions of RealFlight Sim
Old 04-14-2007, 03:35 PM   #1
Jermo
Default Raptor .30 and .50
Raptor 50 for Realflight G3 by Svein over on www.RCHeliSpot.com He's given me permission to post it here provided I add all the copyright stuff and disclaimers.
The Raptor 50 is based on Tony Elms freely downloadable Raptor 30 v2 (see: Tony Elms homepage Here)
Please read the disclaimer and such in the readme.txt file located in the raptor 50 zip file.
Jerry Moore, AMA #878954, IRCHA #2988
Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL
Ok, you can fly...but can you HOVER??
KISS = Keep it simple stupid (to maximize fun and reduce costs!)
Jermo is offline        Reply With Quote
Old 05-18-2007, 12:22 PM   #2
n808
Default Raptor 50 questions
Has anyone been able to load the Raptor 50 color scheme? The zip includes one, but I have not been able to figure out how to import/choose it..
Also, on one computer I tried these on, the Raptor 50 can not find the SAB 601 blades or Thunder Tiger 50 motor, even though the files corresponding to these appear in the Planes and Engines folders. I should probably just re-install from scratch.
n808 is offline        Reply With Quote
Old 05-18-2007, 02:42 PM   #3
Jermo
there's a readme.txt file. IIRC just copy the files over to a specific folder
Old 05-18-2007, 03:23 PM   #4
n808
Thanks. That's what did not work, but I found the problem. The .colorscheme file has a hard-coded filename path in Swedish.. In raptor_texture~Raptor 50 colours.colorscheme, just change c:\programfiler to c:\program files or wherever else you installed RealFlight to..
Old 09-27-2007, 03:55 PM   #5
Raptor44
Default Help Please
I downloaded both the 30 and the 50. Now I have NO idea what to do next?
Please could you explain to a computer dummy excatly step by step to get this to work?
Thankyou Steve
Raptor44 is offline        Reply With Quote
Old 09-29-2007, 09:44 AM   #6
j bomb
Thankyou Steve
You should have saved the files to the "planes" folder in Realflight, if you haven't, move them there. Once you're in Realflight, select "import file" from the simulation pull-down menu at the top-left of the screen. You will then have to choose file type, select G3X. You should then see a list of the files you have downloaded, select the one you want and click "open". To fly the downloaded model, you have to open the "custom" folder when you go into the "select aircraft" menu. You only have to go the importing process initially, after that, you can choose the model from the "custom" folder anytime you want to fly it.
Hope this helps.
John Barta
Michigan Whirlybirds Heli Club
j bomb is online now        Reply With Quote
Old 12-08-2007, 02:14 PM   #7
Raptor44
Talking Thankyou
Thankyu everyone. I finally did it. I can't believe it.
Now if the way I am flying it is any asemblance of the real thing, i'm dead.
Can you help with the setup? or something?
Or am I just that bad at flying a heli?
I can't believe it's that difficult to just try a simple hover? The dam thing wants to go all over the place.
But I'm loving it..............thanks for all the help, I could not have done this without your help.
Steve
Old 12-08-2007, 03:08 PM   #8
MarkWebber
Haven't flown this heli and not to impune your skills but...Yep, that's heli flying for ya! Ain't it great:wink: Keep at it, it get's better
Mark Webber
wai-rc.com
MarkWebber is offline        Reply With Quote
Old 10-23-2008, 03:13 PM   #9
OHaussie
Has anyone tried this for G4? as some of those folder names for G3 don't seem to exist in G4...
SE-V2 - DS-285's, 9650, GY401KB tail blades, micro heli tail rod,H 500 Fuse
TRex 450 SA,carbon frames, carbon boom, Gorilla paddles and tail blades, DS-285's, GY401& 9650 on tail .Scorpion motor TREX-500ESP FBL, JR-11X
OHaussie is offline        Reply With Quote
Old 09-15-2009, 01:05 AM   #10
9G's
Hi, I can't load the color scheme either, I'm sure I have that same problem of yours because when I load the Raptor 50 it says Color scheme not found in C:\Programfeler...
How do I change it to C:\Program files?
Also I was flying the Raptor 30 located in this page, Is it realistic compared to the real thing? Please anyone that have flown the real raptor 30 V2 erply to this. I want to buy a real raptor 30 but I want to be sure the sim is realistic before the first flight.
9G's is offline        Reply With Quote
Old 09-26-2009, 11:56 PM   #11
JKEP44
Wrong forum, sorry.
JKEP44 is offline        Reply With Quote
