| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
dear all, anybody heard something about servo-issues with the stretch-(flybar-)version?
mine crashed today after servo-breakdown, just some flights after upgrading to the 350mm-blades... it seems, my 10-hours flighttime-old hitec hs65-hb servos (4,8/6V (Ncm) 16/18) did not stand the forces of the longer blades... with the 325er-blades (flybar) i used to do up to 30 hours beginning 3d with the hs65hb until i replaced them ... so i was really surprised by the servo-failure... i realised some stearing-weakness the flights before, but unfortunately i did not blame the servos for that... ![]() for now, i would recommend also to upgrade the servos in case of upgrading the whole system... macem Last edited by macem; 08-31-2011 at 05:13 AM.. |
I had around 30 flights flybar stretched, with 2400/2500rpm, soft 3d and using 65mg. Haven't had any problems yet, will change to beastx in a few weeks time.cheers !!
MSH Prôtos |
... 30 flights is not that much... also 2500rpm
... i guess, my servos shifted the blades for 150 flights at 3500 rpm, the last 30 flights with the 350-blades... it seems to me, the force to the servos caused by the rotating blades is not in a direct ratio to the lenght, but exponential... we miss the longtime-experience with 350-blades... macem |
Normally flybared helis put much less strain on servos from both the frequency of updates and the load which is geared down by the link ratios in the head so I would expect to see FBL versions buring up servos all over if there was an issue. There are a few other 350mm blade heli's out there and again i haven't seen any reports of this being a common issue.
I can say that stretching the full size Protos from 425 to 475mm blades hasn't caused a rash of servo failures, even with FBL setups. We still use mini size servos like the DS510 with no issue and people have many hundreds of flights on these setups. //Dennis
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720 SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A |
thank y dennis,
altough - if you are right i have to look for something else to blame for the crash now... macem |
#6 | |
MSH Prôtos |
#7 | |
//Dennis.
#8 | |
http://www.helifreak.com/showthread.php?t=335615 ![]() macem |
#9 | |
so the damaged flybar-carrier i have to replace now could have been the reason not the consequence of the crash... and the other way round for the broken servogears ... ![]() ![]() anyway, hope to be in the air tomorrow... with new servos and new flybarcarrier... ![]() macem |
#10 |
so, what servo did you end up buying ?
I'm a bit confused on what servo to get once I convert to FBL. My personal preference has to be the 5065, but with the ds92 coming and cheap reliable savox is in the market, I might just see what the ds92 is capable of...
MSH Prôtos |
#11 |
... i orderd the cheap savox sh 0254, because it is very strong - i thought i need rather power than speed... unfortunately some days before mks brought his ds92 in the market...
... outherwise this would have been my first class servo ...macem |
#12 |
I have 2 FBL, one stretched, one not. I am running HS-5065MG in both and have had no problems. I would like to try the MKS servos and have a set for one of my big Protos to try out.
Goblin 700, 630, Protos Stretch, JR E6-550 |
#13 |
... i apologize for reactivating this thread, but i think i solved my servo-problems described at the beginning - and this perhaps would be of interest for some others here...
i did realy have some stearing-weakness using the 350blades, and i blamed the servos for that and switched to stronger ones - this was counterproductive ... in fact, the 3a(5a)-bec in the esc i use (robbe roxxy 950-6, 50a) seems to be to weak in combination with 4s-lipos: the bec got hot and reduced power as safety-function, this caused the servoblackouts ... and the stronger servos thigtened th problem... ![]() i hited on it because of some telemetric datas of my new graupner-hott-tx/rx-system - the first telemetric data i ever had... so finally i would recomend to boost rather the bec than the servos when using 350er blades (in combination with 4s)... it is not a servo-issue, there could a bec-issue using the stretch-version macem |
#14 |
No problems with stock esc
Corrado
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 |
It should be noted this is not needed using the stock MSH/YGE esc. The BEC is already switching and will handle 4-6S just fine. Mine barely gets warm (jammed into the nose under the battery tray) and i have it governed at 60% TC.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#16 |
