| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
Is that normal?
The servo frequencies were all off. Tail servo pulse length changed. Swash plate was laid over hard left. Pitch ranges were off by about 100%. Piro comp reversed. Weird. I guess it's no biggie. I just went through the basic set up again and all is right in the world now. Haven't flown yet.Midnight tweaking.lol.... Anybody else get their set up washed by the updater?
Do the best you can until you know better...Then,when you know better,do better To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
There are a few posts here and on the BeastX site that the firmware is very much different and requires a complete setup from scratch.
MSH Protos * 2, SAB 630 |
#3 | |
This is quoted from the beastx.com web forum: "Also note: After updating you will have to redo all the setup! Any former setting will be deleted. This is necessary due to the firmware being completely new. " |
Yes it normal, When you update you have to set every thing up again.
T-Rex 450 Pro FBL ZYX,T-Rex 700 Nitro FBL BEASTX,T-Rex 700 Nitro FBL BEASTX Spektrum DX8,AMA#849731 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
'ight then
So what's the hooplah anyway? I don't know why I changed it. The V2 was plenty awesome to me.lol....
#6 | |
I think one person didn't like V3 for some reason.
SPARTANRC - Forum Support Warp360 |
#7 |
Just be sure to reset any pitch curves in the radio first
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. A Main Hobbies/ProTek R/C Field Rep RotorWorkZ ):> To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
As already wroten by other friends, you should set it up like a new unit.
However, I think the manual has a hole about this thing, for who reads also the manuals like me Ciao, Egidio
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite. Now, TREX 250 SE BeastX/satellite as well. |
