Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-03-2011, 07:40 AM   #1
markleyland
Default Vbar Placement
Can someone please post a pic of how you have the Vbar installed on the 550. The slight issue i'm having is placing the main unit on the inside of the rear frame with plugs at the back, it's doesn't leave much of an option to get to the USB plug as it's on the reverse of the unit. Sensor is on the lower plate. Don't really want to place the main unit on the outside of the frame.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 09-03-2011, 10:20 AM   #2
kfactor
this is how i got my full size not the best but i works i wish i could get my wiring cleaner it drives me nuts
ID:	250967   Click image for larger version
ID:	250968   Click image for larger version
ID:	250969   Click image for larger version
Tbs disco / naza m light / gps with 5.8 fpv
kfactor is offline        Reply With Quote
Old 09-03-2011, 10:57 AM   #3
markleyland
Excellent thank you! I put mine in the same as yours but with the plugs facing out. Found a USB with a L bend in it which just about fits in where your plugs are. How do you get on with vibs having the sensor on top?
Old 09-03-2011, 01:15 PM   #4
kfactor
they are a little high but i dont seem to affect it any
