Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 09-07-2011, 03:59 AM   #1
liftbag
Default Post your brushless mCPx pictures here
I thought this new section of the forum needs a topic that may be useful to collect pictures of our brushless mCP X, with particular emphasis on the components wiring, in order to be useful to those who want to try with the conversion for the first time.
I begin with images of my fleet. Will post the details later.
From left to right:
HP06V2 16200kv/9T - XP-12A (4mm lowered head)
HP05S 13300kv/9T - XP-7A
Spin Brushless Out-Run 14000kv/10T - XP-12A
Feigao FG-MBLN120S 5200kv 2S/9T - XP-7A - Murata Power Solution switching step-down
Gaui 200 Beastx - An unknown number of bl converted Blade mCP X.
liftbag is online now        Reply With Quote
Old 09-07-2011, 04:17 AM   #2
beamen
Crazy! Which one has full throttle resolution, if any?
Are you going to try a 120 tail on one of them, or have you tried that?
Blade mCP X - Spektrum Dx6i
Grommet mod - Extended tail boom - KBDD Blades
beamen is offline        Reply With Quote
Old 09-07-2011, 04:23 AM   #3
liftbag
All of them. All have TheSteve yellow wire connected to the tiny resistor on the back.
I have tried 120SR tail on two of them, but I had the kicking tail issue.
Maybe I'll tray it on the first because it has 7400 rpm crazy head speed.
Old 09-07-2011, 04:44 AM   #4
beamen
Nice
Old 09-07-2011, 06:20 AM   #5
zeitgespenst
Hi,
some pictures of my mcp x brushless genesis.
1. Frame mod with cf motor support, for easy assembly of outrunner and innrunners.
2. Soldering works for converter signal
3. Assembly of bl components
4. Tail mod
5. Final assembly
Current setup: HP05s. 8t, xp7a, Zaunkönig converter
Jens
ID:	251897   Click image for larger version
ID:	251898   Click image for larger version
ID:	251899   Click image for larger version
ID:	251900   Click image for larger version
Name:	Anlöten Signalkabel.jpg
Name:	Montage Kompenten.jpg
ID:	251902   Click image for larger version
ID:	251903   Click image for larger version
zeitgespenst is offline        Reply With Quote
Old 09-07-2011, 07:03 AM   #6
liftbag
Originally Posted by zeitgespenst View Post
Hi,
1. Frame mod with cf motor support, for easy assemply of outrunner and innrunners.
4. Tail mod
5. Final assembly
Jens
I love your main frame mod
Even the wire to the converter input fixed with epoxy on the chip is a great idea
What's the Zaunkönig converter? Any link?
[EDIT]
I found it, it's the nanoheli converter. Do you know when they plan to sell their mCP X upgrades?
Old 09-07-2011, 08:23 AM   #7
zeitgespenst
[EDIT]
Hi,
the Zaunkönig converter is also an Attiny 13 based converter. Got it in the German rcline forum. I have also the Nanoheli and the Thesteve converter tested (and in use), can´t detect any difference in function, but in weight. Enclosed a picture of the Nanoheli converter, the devices are soldered on a circuit board, this is a difference to Thesteve oder Zaunkönig converter, but little bit more weight.
Nanoheli´s mcp x full brushless setups are currently based on a special "Floh" esc for the tail bl motor, which is not available anymore.
Berthold from Nanoheli is also posting in the rcline forum, he reports same progress in "programming" a special tail brushless esc, but I don´t know, if and when it is available. Seems to be difficult ;-)
Jens
Old 09-07-2011, 09:14 AM   #8
dna001
Nice
I see you have now gone with the 4mm lowered head, was this more noticeable over the 2mm you had done before.
T-Rex 700N LogicTech 6100----Chaos 700FBL KDS Ebar
T-Rex 600N FBL OS55--------T-Rex 550FLB Spartan VorTex
T-Rex 450-6S BeastX ----- Nano cpx BL -- McpX BL
dna001 is offline        Reply With Quote
Old 09-07-2011, 09:27 AM   #9
400 flyer
liftbag...
were did you get that canopy??
and out of the 4 you have witch one do you like the best?
2-evo 50's>1-sdx>hawk pro bell 222 /3g/rjx>evo90>freya 70.
trex500esp, scorpion/ ice 75/ 3g/rjx>hirboo embla 450 fbl,ice50,>lepton ex
2 bl mcpx's
futaba 8fgs,,dx7,,phoenix v3.0r
400 flyer is offline        Reply With Quote
Old 09-07-2011, 09:56 AM   #10
liftbag
Originally Posted by dna001 View Post
Nice
Well, I confirm it's a lot more stable in inverted flight.
I had to bend slightly outward of the swashplate guide to avoid touching the head
I shortened the pushrod and...
... I've used the middle servo hole
Originally Posted by 400 flyer View Post
liftbag...
Here you can get the canopy.
The one with the best performance by far is the first of four, but I have serious problems of flight time with the Thunder Power 325 mAh 65C.
I ordered the 550 mAh Hyperions for 120SR, I hope not too heavy.
Old 09-07-2011, 10:01 AM   #11
CX2Pilot
Forum Support
Hi,
4. Tail mod
5. Final assembly
Jens
Hi, can you tell me where you got your cf motor support from? (the ones in your first picture, motor mount and frame support)
I would like to buy some.
Tom
Moderator for the Blade and Walkera Forums.
Walkera V100D01 V2 DBL, Walkera 4G6 w/RX2610V2, Align T-Rex 450SE V2, Blade mCPX V1 BL, Walkera Mini CP BL, Walkera QR Ladybird, Walkera Hoten X, Walkera Master CP.
CX2Pilot is offline        Reply With Quote
Old 09-07-2011, 10:29 AM   #12
zeitgespenst
Hi Tom,
the cf motor support is designed and machined by myself. The idea behind is it´s flexibility and a reinforcement of the frame for strong bl motors. Furthermore setups with pinions from 7t to 12t are possible.
You can assemble all suitable bl motors and change the motors very easy and quick.
I can send you one set next week.
Unfortunately shipping from Germany is expensive, for a registered mail to foreign countries I have to pay appr. Euro 7.00 !
Dont know, if this makes sense, if yes, PM me.
Jens
Old 09-07-2011, 02:30 PM   #13
dna001
Excellent
I am going to try this as soon as I get time. looks like you could still go lower :-)
swashplate guide could be a bit of a problem for me with standard frame :-(
Old 09-07-2011, 02:34 PM   #14
liftbag
Excellent
Next time I'll go for 5mm shorter shaft
Old 09-07-2011, 02:35 PM   #15
dna001
Hay LiftBag, I have your next project lined up for you , he he
Try this with a couple of hs05s
http://www.hobbyking.com/hobbyking/s...tor_Mount.html
Old 09-08-2011, 02:55 PM   #16
mamartin
Here's some pics of mine. I just finished up on it a day ago it's fully upgraded with
Novus heli-max inrunner 9tooth pinion, all micro heli upgrades available except for the frame and it's a RKH frame and an SR120 tail motor
Just as soon as I get comfortable with the new found speed I'm gonna follow TNT and poorrednecks lead and put the 12tooth pinion back on
iKON field Rep
GAUI NX4 with iKON, EDGE blades O.S.37
GAUI X5fes, iKON, Edge blades, CC 20amp BEC pro,
Align 600Npro, iKON, OS55HZ, Funkey B320 3D pipe, Radix Blades,
mamartin is offline        Reply With Quote
Old 09-08-2011, 10:22 PM   #17
sps3172
Here's an alternative for equipment placement and wiring. The battery is inserted from the front, with the canopy off.
sps3172 is offline        Reply With Quote
Old 09-09-2011, 03:47 AM   #18
baui2000
Here's my conversion
And a bonus night shot
Tom
Outrage Fusion 50
HC3-SX, A50-10L Turnado, CC ICE2 120HV, WR Super BEC, DH20-FTD / MKS HBL980
Prôtos Mini FBL Stretch 4S vBar 5.3Pro, MSH 2010kV, YGE-60A, MKS DS95 / DS95i
baui2000 is online now        Reply With Quote
Old 09-09-2011, 04:11 AM   #19
Inverse
Just curious, but what do all your mods add up to $$$ wise?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 09-09-2011, 08:40 AM   #20
Ampdraw
Firstly,
Jens really nice work. Always impressed with your engineering and workmanship.
Baui,
Super neat wiring.
? What esc is that ?
Amp
Ampdraw is offline        Reply With Quote
