| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
I'm moving to FBL this coming weekend and I'm not sure if my current HS5245 servos can handle the load for FBL Beastx.
My mates keep saying that 5245 is less powerful / fast. Is this true? Has anyone used 5245 with beasts on Trex500? Thanks |
They'll be more than good enough , especially if you run them on 6v.....
Peter To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Furion 6 FBL ; E,N and G Whiplash FBL ; 3 Spectra G FBL ;3 Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: Aeolus KME 60 , 2 Velocity 50's FBL; few 500's.. All BeastX ; guided by XPS . |
#3 | |
I think it is more to do with not using FBL blades and placing the beastx on a stable platform. I'm moving the beasts from the receiver tray to the tail block hoping that it will solve the problem. |
Use a really thin , firm mount tape too ,,,,,,
| Tags |
| beastx, hs5245, trex500 |
