Old 09-08-2011, 12:29 PM   #1
RACON450
Default pinions....12T, 15T what it means
Im sorry for all the post but i am on a learning spree to fine tune my brain..can somone explain Pinions for the motors...Like example align gear 12t what does it mean, what should i look for...do i want higher T ratings or lower..what does the t even mean...Helllpppp!!!!!!!
RACON450 is offline        Reply With Quote
Old 09-08-2011, 12:37 PM   #2
[X]Outlaw
T=teeth
example 13T=13 teeth
Changing your pinion effectively changes your gear ratio thereby changing your head speed.
All things being equal (motor KV, cell count, throttle curve) a higher pinion will result in a higher head speed and a lower pinion will result in a lower head speed.
I use this utility to help me determine pinion size for a particular setup.
http://heli.dacsa.net/calcv3/
[X]Outlaw is online now        Reply With Quote
Old 09-08-2011, 12:55 PM   #3
CAP21
There's also Pinion, the great interviewer.
CAP21 is offline        Reply With Quote
Old 09-08-2011, 01:11 PM   #4
RACON450
ok got the whole T thing down but whats up with pinions...
Old 09-08-2011, 01:13 PM   #5
K2Freak
That's the name of the gear that is connected to the motor shaft - the little metal one.
VControl SAB Goblin 770C, BT 650, 570C, 420
#97
K2Freak is offline        Reply With Quote
Old 09-08-2011, 01:46 PM   #6
TheBum
The greater the number of teeth, the faster the main gear will spin for a given amount of motor spin. You sacrifice power when going to a larger pinion though because it loads down the motor more.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 09-08-2011, 04:57 PM   #7
skunkworx
I'm going to go off your name and use a Trex 450 as examples to explain things.
Your gear ratio is essentially a comparison of the big (main) gear and the little (pinion) gear. You take the large gear tooth count and divide it by your pinion tooth count to get your gear ratio (you would use the diameter of each, but the teeth privide a bit of a cheat).
Anway, the gear ratio is used to determine your headspeed provided the voltage and Kv rating of your motor. First, you'll need your motor speed. Let's say 11.V and 3500Kv.
11.1 * 3500 = 38,850rpm motor speed. <--- Now take your motor speed and divide by gear ratio
To find gear ratio: 150t main gear and 12t pinion. That nets you a ratio of 12.5 to 1 (12.5:1), or for 12.5 turns of the pinion gear, it turns the main gear one revolution. If you were to increase your pinion size, you would get the following ratios:
13t = 11.53
14t = 10.71
15t = 10.00
As you increase the pinion size, it uses more torque/amperage from the motor and will make it run hotter, as well as cause more stress on your batteries, geartrain, and blades, but will get you higher and higher headspeeds.
Ok, so now we take the proposed 38,850rpm divided by selected gear ratio (12.5) and you get roughly: 3108 to 3318 headspeed.
If you increased to the other pinion sizes, you would get approximately:
13t = 3108 to 3318
14t = 3369 to 3827
15t = 3883 to 4147
And so on and so forth. The formulas are universal as long as you get all the aspects I pointed out. Comes in handy, but it's probably easier going through a caclulator like Darkhorse.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
