| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I have bought one ARF heli many years ago, and never again.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / T-Rex 450 Sport - 3GX - Tarot head / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 / |
If I brought a kit that was almost or complety built i would strip it down and rebuild it so I would know there is threadlock and grease everywhere they are needed. Also the factory where it is built would be paying for people to build them and paying to ship boxes full of packing marterials around the world, this would create higher prices for us, the end user.
Trex 450 Pro - HS5065's, a few KDE bits and gorilla paddles etc And an Itch for someting bigger, but forcing myself to fly better first. |
You're assuming the company that sells you parts at a significant profit will assemble it in such a manner as to ensure all parts are correctly assembled and locked and aligned as necessary, with employees it mostly pays minimum wage to... Hmm. Wanna buy a bridge in NY? I know of one I can sell you...
Schluter Champion, Kavan Allouette, TRex550E-FB, HC500SE, CloneT450pro-4bladed, Blade 400, WK 4F200, Xaircraft X650, and a CB180D, usually in a tree. |
Same here, plus I really enjoy the build.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar Kasama Srimok ECO CGY 750 Voodoo 400 Mini Prôtos CGY 750 |
#6 |
If you build it you know how it works! Trust thyself. As has been mentioned a bunch. If it's already built you need to un-do and re-do!
G.
T-450 Sport FBL, T-550 V1 FBL, T-600E Pro. Red Goblin 700. Tarot Pro 450 in a scale Hughes. Bunch of little Blades, and Planks. DX8, Full scale Jet Plank Driver. |
#7 |
Also,,, you will need to know how to rebuild it anyway!!
Just ask anyone who flies helicopter for years...!!
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And Trex 450 SA / SE metal head and carbon boom with V2 canopy, 430L motor, Hitec 65mg servo's, Futaba 401 gyro ! T-rex 450 Pro, DFC with AR7200BX To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
I'm starting my Trex 550 build tonight. The first thing I will do is take everything apart, clean off any threadlock that MAY be there, then reassemble with grease and threadlock every place it should be!
Sent from my DROIDX using Tapatalk |
#9 | ||
![]() Mike
Trex700N2E Trex500ESPTT(PRO head and Tail ) Trex500ESP (Belted) HC500SE All flying Spartan, CC100A, CC20APro, Hitec 5245MG, Futaba 9257, Walkera Devo 8S, KBDD, i2! |
#10 |
Since my last crash which destroyed my frame, I'm having to completely rebuid my heli from scratch.
During my debugging process while I was isolating vibrations I had to pull numerous parts off for testing. If you don't want to spend any time building this is the wrong hobby to be in
. Henseleit TDR, Synergy E5, MSH PROTOS 500, 300X Jeti DS-16, FMA PL8, Skookum, Kontroniks, JLog2's |
#11 |
i agree with all of u especially mkavalcson...but sometimes i feel like i am building more then flying...I get over exited and just want to fly..i know most of you can relate...your right about the prfe built ones....I learned on RTF a while back and those kits were complete junk...and by building you learn what is actually happening...althought i always joke how nice it would be to have 1000 back up trex 700 in the garge so if you crash your pit crew can get you another...like a real life simulator.....when you guys say build how fast can you build say a 700 or 550 size..im a about a good month...thats kinda long huh?
#12 |
I have taken mine apart and put it back together so many times it is silly. From upgrading the engine to changing how the wiring is run, I have tinkered and tinkered. Plus, I have had one crash. I can pretty much put this thing together blind folded...well maybe not blind folded, but I can assemble it in an afternoon.
Once you know exactly where everything goes, no more time looking at diagrams or reading...or posting build questions online, it will go together really fast.
Trex 600EFL PRO (BeastX, Rail 606 blades, Kontronik 80HV) Trex 450 PRO FBL (BeastX, HS-5065/BLS257, CC ICE Lite 50,) mCP x (KBDD blades and tail) |
#13 |
My 550 was put together in a few days but I was taking my time by investing 2 hours each night after work. I think 4 to 8 hrs to do a complete build if you have all parts. I had to order a few additional parts for mine so that was another part of the delay for me.
For a larger heli, a 700e for example, I would think that would be about the same or less due to the larger parts and how much easier it is to handle them. My 250 took longer than the 450 or 550 believe it or not. The build time includes all assembly and configuration requirements to make it RTF. Yes I am anxious too to get it airborne but I fight the urge as I want it to fly properly and not have issues (crash due to missing something critical, well almost all items are critical aren't they?)
Carl Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544 |
#14 |
My Beam came as lots of bags of little parts, just the way I like it.
If it comes pre-assembled it just means I need to take it apart before I can start the build. Mind you, the building and tinkering is as large a part of the hobby for me as the flying.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain Tarot 450 Pro - AR7200BX Spektrum DX8 Last edited by Inverse; 09-10-2011 at 11:37 AM.. |
#15 | |
#16 |
My Dad had me build his 500 a couple of years ago even though I advised him he should, but he had it posted to me anyway. I enjoyed building it but he still hasn't learnt to fly it very well as he is afraid of crashing it. He recently had a tip over and waited for me to visit (he lives miles away) so I could fix it for him. I keep telling him he has to learn and take a good look at Helifreak. Moral of the story is if you get someone to build it for you, you will end up like my Dad
"Sort your head out and fly with your heart" Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc, Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251 |
#17 |
I stripped a gear today on a fast loop. I couldn't wait to get home and rip it apart. I like fixing my helis, all of it, and i like flying too
JT TRex 550FBL SK720 TRex 500FBL Airwolf Goblin 700 HC3-SX |
#18 |
My first heli a couple of years ago was a "RTF" model. There were several places in the manual were it was stated that the heli was test flown in the factory prior to shipping. There was even a video on-line showing a company rep demonstrating that the heli could do "hands-free" hovering right out of the box. That was when I learned that RTF really stands for Ready To Fix.
This month I built my first TRex 550E FBL. It is my seventh heli. I found I could not assume anything regarding the pre-built assemblies. At least Align confirmed this in the documentation. I found everything had to be taken apart, inspected and re-assembled. ARF really stands for Absolutely Ready To Fix. These manufacturers are like any other business. They want to maintain their profit levels. Part of this means keeping the labor cost low. In some parts of the world, this means really low. Of course, when you pay peanuts you get monkeys.
MQX Quad,Align 550E/NazaH/GPS,Align450 Pro/CPII, Flame Wheel F450 Quad NazaM/GPS/GoPro2 Never lend money. It causes amnesia. |
#19 | |
A Main Hobbies |
