Old 09-09-2011, 10:29 AM   #1
jabu32
Exclamation Please Help Identify Part on Board.
can anyone determine what kind of component is right under the main motor plug? it is a black two leg part. i cant tell if it is a cap or a diode. i replaced one of the main motor fets and noticed this was also damaged. thanks.
Hello My Name Is Joe
Blade 130X - Lynx EOX / Blade 300x - AR7200BX, 2213-3585 / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX / TSA 600e Pro - AR7200BX, 700MX / TBS Discovery FPV - APM, Sunnysky 980kv/ DX8
jabu32 is offline        Reply With Quote
Old 09-09-2011, 11:58 AM   #2
hydro_pyro
Usually it's a small signal diode, to shunt back-EMF discharge from the motor. Usually it will still work without it.
Blade 200QX, Align T-Rex 450 Pro 3GX,
P-51, SU-26XP, Carbon Cub, Cessna 182,
F/A-18, Blackjack 29, Slash 4x4
hydro_pyro is offline        Reply With Quote
Old 09-09-2011, 12:48 PM   #3
jabu32
ya its a diode. can you tell me the markings on yours if you can. i think you would need it to regulate the voltage.
Old 09-09-2011, 06:59 PM   #4
tjhelipilot
I agree with hydro....it's a small signal diode to shunt back EMF.
Look on Digikey for a 1n4001 in that package size, that'll work.
tjhelipilot is offline        Reply With Quote
