Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 09-09-2011, 08:28 PM   #1
wicked_n_raw
Default YGE Videos
Here is the first part of the YGE videos that I have done. I will be doing more including how to set it normally and how to set it up with the vbar. I am also including a link to all the manuals and some tips documentation.
Here is the first video on the program card II.
For the documents
manuals http://elektrorc.com/article_info.php?articles_id=2
Programming http://elektrorc.com/article_info.php?articles_id=5
Gov Store http://elektrorc.com/article_info.php?articles_id=6
Error Codes http://elektrorc.com/article_info.php?articles_id=7
If you think I should add something to the videos or take something out please send me a pm.
Best Regards
Furron
Goblin, Pulse Ultra, Canomod
wicked_n_raw is offline        Reply With Quote
Old 09-09-2011, 09:16 PM   #2
Mystic3D
AWESOME.
Thank You Furron
Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar
Mystic3D is offline        Reply With Quote
Old 09-09-2011, 10:08 PM   #3
wicked_n_raw
You are welcome!
Best Regards
Furron
Old 09-09-2011, 10:39 PM   #4
fusionsx00
just in time
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is offline        Reply With Quote
Old 09-10-2011, 10:38 AM   #5
joe1l
thanks man!! very good video!
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
ElektroRC.com field rep (YGE, MSH, LAHeli)
joe1l is offline        Reply With Quote
Old 09-10-2011, 03:28 PM   #6
velocity90
Great vid wicked,
Be sure when making one for the vbar to mension that the rx channel of the program card for programing end points goes in the thr channel of the vbar, NOT channel 3 on the receiver fur futaba. I cant comment on spektrum but it goes in the vbar. Dont use the receiver anymore for programming endpoints.
Also be sure to be in "stick control over moter" mode on when programming the end points (stop and full speed) This is the key to making it work flawlessly.
Logo 600 - PD-Scorpion 4225 470kv+vbar gov/YGE120hv/Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+
Hobbymaniac Teampilot
velocity90 is offline        Reply With Quote
Old 09-10-2011, 11:03 PM   #7
joe1l
can we make this link sticky!
Old 09-13-2011, 07:52 AM   #8
jhheli
Yea this should be a sticky, nice videos.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
SAB USA, KONTRONIK, PRC, CANOMOD, PULSE ULTRA
jhheli is offline        Reply With Quote
Old 09-13-2011, 06:44 PM   #9
wicked_n_raw
Thank you everyone.
Here is the second video.
Best Regards
Furron
Old 05-10-2012, 03:26 PM   #10
helidude71
Great vids!
However you recommend to go for 3.4V/cell cutoff voltage.
My own testing shows better not do this.
I've run into LVC with this setting and the charger shows 27% left in the pack.
With cut off type "slow down" there isn't enough power to even hover my bird.
It's clear you want to prevent LVC unneeded.
I would recommend not to go any higher than 3.2V/cell cutoff voltage.
IMHO
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75
TSH Gaui X5 FES, Microbeast v3, S.Bus, DS610s, DS650, YGE 100LV
Futaba T7C
Phoenix R/C v4
helidude71 is offline        Reply With Quote
Old 07-03-2012, 10:46 PM   #11
laminarjack
Thanks for the great videos. I got my HK YGE ESC programmed and will give it a test flight tomorrow. Good stuff, the instructions were crap.
laminarjack is online now        Reply With Quote
Old 11-19-2012, 04:13 AM   #12
Valkman
Many thanks mate.
Valkman is offline        Reply With Quote
Old 12-08-2012, 08:32 AM   #13
3bncbm
http://www.youtube.com/watch?v=a7kbMhBaUA4
For the documents
This video has gone private. Any reason for this?
3bncbm is offline        Reply With Quote
Old 12-09-2012, 02:41 PM   #14
K2Freak
Yup. I'd like to watch these as well, but not allowed.
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 12-11-2012, 08:53 AM   #15
alexmit
Default MrMel's Setup Videos
External Gov with YGE
YGE Programming Governor Store
Thanks MrMel!
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 12-11-2012, 11:33 AM   #16
3bncbm
http://www.youtube.com/watch?v=zbO67N-Ym0o
http://www.youtube.com/watch?v=ITCevmKW3oQ
Thanks MrMel!
Thank you for this! Just can't understand why a "Sticky" would be private?
Old 12-21-2012, 10:46 PM   #17
wicked_n_raw
Sorry forgot this was here!
Best Regards
Furron
