Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 04-18-2007, 03:22 AM   #1
sniky
Default Separate BEC
Hi All! I'm planning to get a Trex SE V2, HS-65MG for cyclic, 9650 for tail, and Gyro 401. I think I read somewhere that you need a separate BEC/UBEC in this kind of setup since sometimes the ESC cannot supply enough power to the receiver. Is this true? Can the standard ESC that is included in the kit supply enough power to the receiver? If I need one which UBEC do you recommend? Thanks in advance.
sniky is offline        Reply With Quote
Old 04-18-2007, 04:34 AM   #2
Pinecone
You don't need one, but many people run one. I use a ParkBEC 6V. The volts speeds up the servos at the expensive of possibly shorter servo life.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 04-18-2007, 04:35 AM   #3
kgfly
You only need a separate BEC if:
* You run a 4S setup
* You run digital swash servos
otherwise the BEC in the Align 35A ESC will be just fine. If you want an external BEC for the T450 then the DimensionEngineering ones are very good and very simple to use: http://www.dimensionengineering.com/ParkBEC.htm or http://www.dimensionengineering.com/SportBEC.htm
Otherwise there are lots of sub-$20 switched-mode BECs around these days, eg http://wattsuprc.com.au/product_detail.asp?pid=EW-UBEC
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote
Old 04-18-2007, 07:19 AM   #4
sniky
Thanks. I guess my setup will do while I'm learning. So if I understood you correctly, it is ok to fly the trex without the separate BEC. And it won't contribute to it crashing or glitching just because the power to the receiver/servo is not enough.
Old 04-18-2007, 07:32 AM   #5
kgfly
If you are running a 3S (11.1V) lipo with this: Trex SE V2, HS-65MG for cyclic, 9650 for tail, and Gyro 401 then that's right, the built-in BEC will be just fine.
Kenneth
