Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 09-10-2011, 04:12 PM   #1
Dongskie
Default 315mm Vs. 325mm Main Blades on a 450
315mm vs. 325mm Fiber Glass main blades on 450 Heli
I used to have a Belt CP heli and have 3 pairs of blades for it, when I sold it I got to keep the spare 2 pairs which the new owner didn;t want to keep.
Lately I got an HK450 ver2 and out of curiousity used the 315mm main blades on it.
I was suprised to expereince a different handling characteristic and crisp response form the heli which I did not experience with the 325mm blades.Both 315mm and 325mm blades are made of fiber glass.
Using the 315mm blades it spooled faster, got crisp cyclic response and faster transition. I also felt that the heli moved faster from point A to point B and at a lesser cyclic input. I prefer to use this from now on
I am baffled by the result but was extremely happy about it. I've always thought that a shorter main blade will give it lesser responsiveness and performance.
Anyone can explain the physics of it, I am all eyes
Thanks guys!
Ed
ESKY BIG LAMA - ESKY BELT CP CARBON EDITION - HK500GT - DYNAM T-28 TROJAN
Dongskie is offline        Reply With Quote
Old 09-16-2011, 12:53 PM   #2
chopstick
I have flown 315mm blades on my 450. These behaved like you said. IMHO you can use them without any problem.
LOGO 400SE : Skookum SK540, Scorpion 3226 1230kV
SJM180 : Tarot ZYX
Rigidheli.com: The place where Dutch Helipilots meet
chopstick is offline        Reply With Quote
Old 09-25-2011, 11:28 AM   #3
Digger1973
Mini Titans come with 315 mm blades. If that is of any help. No reason why they wouldn't worlk well
Digger1973 is offline        Reply With Quote
Old 09-25-2011, 04:48 PM   #4
Dongskie
Thanks guys!!
Old 09-30-2011, 05:39 AM   #5
kouasupra
315mm will give you more flight time, but you aren't going to be able to get more hang time in maneuvers. 315mm also don't auto as well. 325mm creates more lift making it easier for tic tocking, and auto'ing. Both blades has their pros and cons, and are use for different flying style. Only you can determine what you like.
kouasupra is offline        Reply With Quote
Old 09-30-2011, 01:52 PM   #6
Dongskie
Thanks kouasupra:
I really wanted more flight time, I am no 3d flyer anyway.
Old 12-15-2011, 09:10 PM   #7
TexasC
the 315 mm blades are shorter therefore the center of gravity is closer to the center of the head. This results in less torque and since the blades probably weigh slightly less than the 325 mm ones, there's less sprung weight.
All this means is that the motor can spin the blades faster and easier making your heli feel more agile.
TexasC is offline        Reply With Quote
Old 12-24-2011, 10:21 AM   #8
satgod
because of the slightly shorter blades your headspeed can be slightly higher which is a good thing and you wont loose power as much in high collective moves
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 12-24-2011, 07:50 PM   #9
crf69
i went from 335 to 325 and noticed a mega difference on Walkera V450D01
may try 315
Buy good stuff then you never have to apologize to yourself for being an idiot....
Stay Inverted My Friends. Ryan Robinson 7hvGob7GauiX5Warp360SYNE5
"How high does it go?" Love that question.....
crf69 is online now        Reply With Quote
