Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-11-2011, 02:59 AM   #1
bdtrauma
Default Slop
I noticed a bit of movement 1-2mm when I picked up my 550 by the head. Is this amount of upward downward mvmnt normal?
bdtrauma is offline        Reply With Quote
Old 09-11-2011, 04:04 AM   #2
rctazz
If you are talking about movement of the shaft up and down 1-2 mm then no it's not normal. You use one (or more) of the shims supplied with the Heli or if you don't have them...
http://helidirect.com/align-main-sha...0e-p-19678.hdx
to take out the slop. The jesus bolt should slide easily through the gear set but the shaft should not move up and down. If you have movement it and can create unexpected responses in pitch.
One other thing to make sure is that your bearing blocks are installed correctly.
Jim
Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700
Keep it off the Ground....but just barely
rctazz is offline        Reply With Quote
Old 09-11-2011, 05:26 PM   #3
bdtrauma
thanks... there is a lot amount of movement.... i just measured 3 mm up/down... something isn't right. ... is there a picture that shows the bearing blocks correct position?
thanks
Old 09-11-2011, 05:57 PM   #4
bdtrauma
rc..... you were right on. I flipped the blocks over and now it is snug and no bobbling.
thanks again.
Old 09-11-2011, 07:01 PM   #5
rctazz
thanks again.
No Problem, glad I could help. Always remember the lower bearing inserts from the bottom and the top bearing inserts from the top...at least for Align Helis.
Jim
