| Henseleit Henseleit Helicopters |
Christmas came early today. Got my new speeder ESC - 320A should be enough...
It will power a Croco 4535 "speed" (4+3 YY) along side a WR Super BEC. Kinda makes the Jive 120 look tiny: |
Big. But not that much for the current it should handle.
Nice.
- TDR #2, 4525LE, YGE 160HV, MKS HBL950 (JR MP82S=crap), Outrage BL9188, Gryphon Quasar, silver Vbar + 2x sat, 12S Billowy 50C 5200mAh, Radix V2, EDGE 105mm, DX7 - TDR #1 sold (standart setup, 700+ flights) - HPI e-Firestorm FLUX, Spektrum DX3S |
Which one did you get? 4+3 sounds like at least 1.8.
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-DJI-F550 |
swwwweeet !!
#6 |
Is that a prototype? How much $$? When will it be available?
NO FLYBARS |
#7 |
The YGE320HV is so far only made to order. Not sure if there are enough crazy people around to warrant a real production...
Here's the motor: |
#8 |
There'll be a small LE-series of 4535 with 1.6mm wire soon, 50 pieces only...
-Klaus
#9 |
Sweet stuff to look at but hey guys those are machine breakers, just no way you can use all that power in a TDR! I find with my 4035 handwind in 1.32 that it's already borderline for 3d work. But i guess for speed runs at 18 degrees you'll be ok.
Man but that motor looks good will have to do one someday! As they say why do we do it? the answer stays the same because we can! Post you results edvard, thats if u have enough lipo to make the first turn back to base I can only magine how many more stripped gear questions are gonna make it to the forum when 1.6mm le becomes available Klaus Maybe it would be a good thing if we make a sticky showing different motor options and application, speed vs 3d, combination of both etc. |
#10 |
The motor above is specifically developed for speedflying. It won't do 3D very well. My 4530 Speed Croco so far was able to pull quite a bit too, and I have never stripped a gear because of motor power. Remember there is not a lot of stop-go in speedflying - the motor just oinks away fairly consistently. The key is to gradually increase the load.
Even my current 4535 Croco 3D motor has not (yet) stripped gears, but then again it takes me about 4-5 flights getting the gear mesh just right. I think the production 4535LE will be a 3D motor, but not sure. These motors will eat all they can, so good lipos is a must. |
#11 | |
About gears... I'm exchanging my gears right now. First stage looks okay. Second stage has some terrible marks which happened at a single cyclic stick move. Bigger problem is the head. The outer (hard) damper breaks into several pieces if you don't fly carefully. -Klaus
#12 |
No -one better than you to do the sticky klaus please post your data. It's obvious these motors are too powerful for anything but speed flying. Personally i think the limit for 3d is something in the pyro black edition, 4525, range. I'm gonna handwind a pyro in 1.32mm yy which should come out ahead of the black edition and will see how that goes.
Where these powerful motors seem to get in a zone of their own is low headspeed 3d. But one has to have sensitive fingers when upping the headspeeds. Klaus please post a video of your flying i must see how you wear out dampers in couple of flights! What is your headspeed and what governor. I'm sure gov settings less agressive will benefit the gears to a large extent. Dampers, maybe we should make you some magnetic dampers that cant wear out! Edvard apart from the heatsink what do you do to keep temps down or is a hole in the canopy enough at speed? Also what pitch and headspeed youre gonna run on this machine? |
#13 |
INCREDIBLE!!! Congratulations for motor and esc! what amp consumption you estimate in speed flight for decide to use this esc?
ROCK 'N ROLL www.gmaurobrushless.it |
#14 |
http://www.powercroco.de/12N10P4535.html some logs on the 4535
also video of 4535 but slower kv, impressed by the flight times apparently on not so good lipos |
#15 | ||
#16 |
Congrats mate, they sure look like they mean business
With great power comes great voltage times great current ! |
#17 |
Edvard, which type of batteries are you using and how long will these last?
#18 | |
I usually don't fly for more than 3 minutes at full throttle. |
#19 |
Spill the beans roughly how much? over $700US? does it have phase sens output and what does it weigh compared to jive?
I would like to see it mounted, i guess you will solder straight to motor? I think the diabolo may handle power better, pity grips and shafts are stiill small. Klaus i think the vbar gov and your fngers are the problem. I must admit better oring carriers would be good |
#20 |
Wow... this is cool.... I LOVE, LOVE, LOVE overkill.... (mostly cause I can't fly 3D anyway, so I don't break anything) That would be so flipping cool. I really need to start upping my flying skills, I don't need 3D for some speed runs....
![]() As a side note, can you only order those power croco motors overseas? And, does anyone happen to know if they ship to US? Nice work Edvard.... Can't wait to see it in action! Good luck, Joe_Breezy
Diablo, Shape 9.0, Goblin 700, Sylphide 90, Srimok 90N, Srimok 90E, Dune, Vibe 90SG FB & FBL, TDR, 700E F3C, E-Aurora, Raptor 90SE, Logo 600SE, T600 ESP, T600NSP, Synergy E6, N5, Logo 500SE, Vibe 50, Warp 360, Gaui NX4 & X4,T500, T450 Pro FBL, 130x |
