Old 09-13-2011, 06:21 PM   #1
Elliott000
Default dx8 servo settings
Hey there, if I am in the srvo settings and I am on gyro.... what exactly is this adjusting? whether I be on travel, sub-trim, reverse or speed i see no physical movement... where as on rudderi I can see changes in ym adjustments.
Also Im not very clear on what Dual rate and expo do... im new to the heli game will either assist me in learning to fly?
lastly lol just what the heck does gyro gain really mean. I have a trex 450 pro and am unsure whats a good gain to start out at. I do understand that - gain is rate and positive is HH
Elliott
Elliott000 is offline        Reply With Quote
Old 09-13-2011, 07:16 PM   #2
aerocal
In the servo setup menu leave all the values for the channel labeled Gyro at their default settings.The channel value will be controlled by the Gyro menu.In the Gyro menu all values that are + will be gain towards the HH(heading hold) side and all - values will be gain towards rate mode.
Gyro gain is sensitivity.As far as a good place to start he gain at it may depend on the gyro but generally Id say about +30%.If the tail wags back it off .If its not solid and drifts put some more in until it wags then back it off.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote
