Old 09-14-2011, 10:10 PM   #1
skered53
Default swash cmpensation more agressive now !
on my preflight checks, i check the tail movemen then the main swash for their reactions to me tilting the airframe, the tail moves the same quickness, but the main rotor swash moves much more agressively now. I did re do the collective and cyclic range of movement adjustments just to try and get comfortable with making said adjustments.
Did I increase the range of my cyclic throws ? I guess since i didn't measure them before = I have nothing to compare them to if I measured them now. Next chance I get I will measure them just to know, what i did was just reduce them so there was no binding. A good thing out of all this is that i noticed the swash tilting the wrong way when pre-flighting, so I double checked Step M and it was reversed, so i changed it from blue back to red. I must have changed this along the way .
Still a BeastX newbie.....
T-rex 500FBL BeastX, I2 MRH & Swash, I2 tailboom holder TT version,( Bob's the Mahn ! ) DX7s. Gaui 550 FB, T-rex 550 I2 FBL head.
CH-53E's 83-87. MCAS New River. FAA certified Airframe & Powerplant license holder since 1992
skered53 is offline        Reply With Quote
