Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 09-16-2011, 09:53 AM   #1
pwkpete
Default VBar upgrade for LV controllers
Hi everyone,
YGE just announced to me that the LV controllers can be upgraded to support VBar governor as well.
The charge for this is 35Euros - it will be a hardware and firmware modification and will include the additional phase sensor cable output from the ESC.
New LV controllers with this feature will cost 35Euros more, so there will be an option of an LV ESC with and without this addition.
-P
LAHeli Ricco / Sniper, MSH mini Protos / Protos - YGE/BeastX - ElektroRC
pwkpete is offline        Reply With Quote
Old 09-16-2011, 10:02 AM   #2
joe1l
Very nice ! Thanks pete!
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
ElektroRC.com field rep (YGE, MSH, LAHeli)
joe1l is offline        Reply With Quote
Old 09-18-2011, 12:52 PM   #3
prototype3a
How long till you have a 40A with this?
prototype3a is offline        Reply With Quote
Old 09-18-2011, 07:06 PM   #4
pwkpete
Will be in the next order in about a week and a half, waiting on some other controllers to become available
Old 09-20-2011, 12:08 AM   #5
Long Nguyen
Man I wish I had bought my YGE120HV right now so that I can have the upgrade. Mine is flying so good and I don't want to miss it for 3 weeks!!!!
Long Nguyen
Long Nguyen is offline        Reply With Quote
Old 09-20-2011, 07:50 AM   #6
pwkpete
Glad to hear it's working well, Long!
The external governor update was supposed to be completed at the end of October. Unfortunately (or fortunately) I got the last shipment with an, "Oh by the way - ", these all have the update
-P
Old 09-21-2011, 03:20 AM   #7
fusionsx00
Hmm, if I had my sk720 in there I would need that.
I'm waiting for v-bar to release there new sensor
Then I might get that and a new yge with the upgrade.
Now why aren't the larger company's doing this?
This is a smart move by YGE
Dx8 mCPX bl v1 hp05s130X
GauiX2FESds11,ds95i beastx
Gaui X5FES,AR7200BX,Xera4020Torq9088,9188
fusionsx00 is offline        Reply With Quote
Old 09-21-2011, 07:24 AM   #8
zeeflyboy
So just to understand, this will basically be a built in phase sensor that feeds the RPM information to the Vbar/Skookum/whatever and removes the need for a separate one? And you have two cables from the ESC - one to the governor port and one to the normal throttle port?
If so, is the only advantage to this that it removes the need for a separate phase sensor, or are there more important changes under the hood, as I was under the impression that the YGE's worked fine with external governors anyway?
Anyway, great move by YGE... really nice to see that the company is driving things forward.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is online now        Reply With Quote
Old 09-21-2011, 08:04 AM   #9
prototype3a
One advantage of having the rpm data being fed to the FBL box from the ESC is that it is much more reliable and accurate than the phase sensors. I get quite a few phase sensor errors on my v-bar gov heli using the hyperion sensor.
Old 09-21-2011, 09:11 AM   #10
Mystic3D
I can confirm that my VBar Log shows a Lot less "Gov input" errors since I moved from the Hyperion to the YGE Sensor.
Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar
Mystic3D is offline        Reply With Quote
Old 09-21-2011, 09:12 AM   #11
Long Nguyen
My hyperion phase sensor induces some errors too! Man this really convinces me to stop flying for a few weeks and send the ESC back for an upgrade...
Long Nguyen
Old 09-21-2011, 10:58 AM   #12
zeeflyboy
Cool, thanks for the info...
I guess I need to put another one of these on my shopping list soon!
Old 09-22-2011, 04:05 AM   #13
Norman_nitro
Hello guys ,
I have some question about yge 160HV.
Is it can upgrade with built in phase sensor?
Thanks guys
Norman_nitro is offline        Reply With Quote
Old 09-22-2011, 08:03 AM   #14
pwkpete
Depends on the build date. You should talk with your reseller - they can work with YGE to find out.
