| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
Started setting up my Beastx last night on my rebuild. Destroyed my FB Trex 550 when I dumb thumbed so I made the jump to FBL. All stock components with the Align FBL head.
My question is about the light while setting the cyclic limit in step L. To get it without any binding it's in the red light range. With the blue light the elevator binds big time on the antiroataion bracket, and yes that's with the spacers on the servo mounts. With it set without binding and the red light I can still get 12*. I know in posts and in the manual it says to get 10-12, so I'm guessing it's ok, plus I'm not in the purple or no light at all. Just wanted some opinions. If it matters on step J it stays on the blue light at 6*. Thanks |
#2 | |
Ciao, Egidio
GAUI addict: EP100 PRO, EP100 V1, EP200 V2 BeastX/satellite, EP255 BeastX/satellite. Now, TREX 250 SE BeastX/satellite as well. |
I don't know why I didn't think to search the 550 forum also, found this thread and a few others http://www.helifreak.com/showthread....evator+binding I'm going to look today and see how bad the link is hitting the ar bracket and how much I'd have to grind/file so the link can move enough to stay in the blue light without binding. If it's possible I'd like it to be in the blue light. BTW, I forgot to put this is binding at full positive collective with full forward cyclic. At full negative collective I can keep it in the blue light and nothing binds. This is also with 12* +/- collective. |
My 550 had terrible binding on elevator, and I guess would only have been giving me red. I didn't like that, so I simply filed the AR bracket away until I could completely max out the cyclic even at full collective. It wasn't that I thought I might need so much cyclic, not sure, but I thought the MB might when in some extreme circumstance. Anyway, here is a picture of where I filed it, maybe it will help. Mine is a stock FB with an Align FBL head too, and this filing hasn't given me any issues, and of course it now gives me blue.
Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1, FBL Trex600ESP µB, Parkzone P51D |
Thanks! I feel the same, I don't know that I'll ever need that much cyclic but I'll feel better knowing the Beastx is at it's optimum setting.
