Old 09-17-2011, 12:48 PM   #1
Z900
Default Best way to setup mechanical the tail
BeastX loves to setup the tail mechanically so that the tail
is not moving in normal mode (+/-7 or 8degr. pitch on tailblades) ?
Or just 0degrees pitch at centre stick?
Its for the TD-Rigid with Logictech 6100 servo.....
| mCPX BL@DX6i | Trex700N-LE@BX | TDR@BX || FunJet 2W20@4S | SwiffieII || FF10 || 720i DUO3 | ALC8500
Z900 is offline        Reply With Quote
Old 09-18-2011, 02:10 PM   #2
Z900
Nobody knows which mechanical setup the BeastX prefers ??
Old 09-18-2011, 03:14 PM   #3
hamstar78
get no drift in rate mode then swithc to healding hold and fly
hamstar78 is offline        Reply With Quote
Old 09-18-2011, 03:27 PM   #4
Z900
so with the tail servo arm 90..... then about 8degres pitch on tailblades ?
Like the LTG6100 wants.
Old 09-18-2011, 09:00 PM   #5
SkyRaptor
I'm using 0º pitch with 90º servo arm just because it is easy to setup..
Good Heading Hold gyros doesn't care if "neutral" pitch is 0º or 7º... it will just place the servo in the correct position to keep the heading.
I'm using V3 and the tail is nothing less than perfect.
Best Regards.
Alex.
SkyRaptor is offline        Reply With Quote
Old 09-19-2011, 01:41 PM   #6
Z900
OK Alex...then I leave it as it is (thats what you said)...thanks !
