Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Others
Others Walkera Other Models Helicopter Support
Old 09-18-2011, 09:04 AM   #1
bktho7771
Default V120D05 drift back and right with low battery power.
My v120d05 will drift right and back as the battery gets low. It starts off flying solid. I can hold it in my hand with out moving it and give it constant throttle, and notice the servos telling the heli to bank back and right. I can correct it and it starts it again. The lower the battery gets the worse it gets. Any one have any thoughts, similar problem, or advice to correct this. The only way I know of is to create a program mix and turn it on about half way through the fight to counter act the receiver. As far as I can tell this is not a mechanical issue, and it does it when the gyros are turned off.
bktho7771 is offline        Reply With Quote
Old 07-13-2012, 09:27 PM   #2
Hamper
Holding heli in your hand will act totally differnt then free flight just tossing that out there
Hamper is offline        Reply With Quote
Old 07-15-2012, 11:43 PM   #3
minidan
couple times when I forgot to use a timer my D05 got real squirley when the batery got low. My 4G6 will do the loose rudder control when the bat starts to get low.
minidan is offline        Reply With Quote
