Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters
Hirobo Nitro Helicopters Hirobo Freya Evo Eagle Helicopters Discussion
Old 09-23-2011, 09:44 AM   #1
Isaac F
Default Hirobo Factory KIT 0305-901 for Shuttle Electric Conversion
Hey guys,
I dont know if you are aware that Hirobo has released a Factory KIT 0305-901 for Shuttle Electric Conversion.
Have any of you has try one?
I will like to use it on a Shuttle with a Funkey 222 Fuselage.
Check this site:
http://model.hirobo.co.jp/products/0...onversion.html
It has all the info
THX,
Isaac
Isaac F is offline        Reply With Quote
Old 10-27-2011, 04:42 PM   #2
Shuttle RG
Thanks for posting!
Shuttle RG is offline        Reply With Quote
Old 11-24-2011, 02:25 PM   #3
hawker007
Default 0305-901 Compatability
I was also wondering if the hirobo kit 0305-901 will fit the original shuttle ZXX. Can't seem to get confirmation anywhere?
hawker007 is offline        Reply With Quote
Old 12-03-2011, 12:51 AM   #4
trash
I just did this conversion to my old shuttle. I still have the original steel clutch bell so I guess that makes it a zxx or similar...? I would say that this conversion will fit all shuttles but am not 100% sure of that. I have a 4500mAh lipo and a 75 amp CC ice controller and it hovers solid for 14 min 45 sec, pulling 15.5amps, until low voltage cutoff. I had a gentle forward flight of 17 min 10 sec as well and only put 3900mAh back in. I am using the governor mode in the esc and have the head-speed set at a low 1400rpm. I don't think it is a 3D setup, but for a scale machine the spool up and gentle flight characteristics are spot on.
http://www.helifreak.com/showthread.php?t=361087
trash is offline        Reply With Quote
Old 10-16-2012, 10:22 AM   #5
lcdlizard
Default Hirobo shuttle dfc
Hi all the link you want is http://model.shinlog.jp/.s/hirobo_fa...izer-less.html this shows the flybarless electric kit all parts are the same as the sxx shuttle realeased a few years ago I have been working on a dfc flybarless shuttle which flew on Saturday for the first time please see the u tube link flight video to follow thanks ray
lcdlizard is offline        Reply With Quote
