Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 09-23-2011, 10:39 AM   #1
ray.johnson8
Default Tail blade balancing
I watched the finless bob video on how to balance main blades and was wondering how to balance tail blades. Is it the same just on a smaller scale? Also, what else should I look for when it comes to balancing the helicopter? Should I balance the flybar and paddles?. I am new to helis and am building my first trex 500. I have name brand everything except for blades and just want to get it right.
ray.johnson8 is offline        Reply With Quote
Old 09-23-2011, 11:23 AM   #2
BaconRaygun
Same way.... I balance my tail, mains and paddles.
With the flybar itself, just make sure its 100% even on both sides when you secure it... you don’t want one side to be 1 few mm longer than the other.
~Outrage~ Fusion 50 (FB) ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team Boca Bearings****Team LYNX Heli Innovations**
The member formerly known as Vicovaludemero
BaconRaygun is online now        Reply With Quote
Old 10-05-2011, 08:19 PM   #3
JTAnimal
I don't know about you guys but a balacer will not work on tail blades for me. most tail blades for a 550 / 600 size weigh anywhere from 3 to 6 grams and that is not enough weight to balance on a normal balancer. i wound up buying a scale that goes as low as .001 gram. but I question if .01 gram off will make a defferance.
JT
TRex 550FBL SK720
TRex 500FBL Airwolf
Goblin 700 HC3-SX
JTAnimal is offline        Reply With Quote
Old 10-08-2011, 10:58 PM   #4
alexf1852
Balancing the tail blades in the grips and with the tail hub and bearings etc is the way to go. Use the Du-Bro prop balancer.
MSH Protos * 2, SAB 630
alexf1852 is offline        Reply With Quote
Old 10-09-2011, 04:33 PM   #5
joliecoeur13
since I don't have a Dubro balancer I'm going with the crap shoot aproach !! works great ...
first REMOVE THE MAIN BLADES , without saying the tail blades need to be the same weight ! then I spool up and touch the boom by the fin , you will feel any vibration , if I feel vibration I stick a very small pc of tape (1cm x1cm) in the midle of one tail blade , spool it up again and it either is better or worse , if worse add the tape on the other blade.... until 0 vibration
On my Logog 500 my sk720 vib log is 1 out of 10 ...
E7 - MSH Brain- HW 120HV- BLS 451-693's
Protos 500 stretch- Robird31- JR3400- BLS251-470's
[COLOR="Red"building: Diabolo- MKS 665- Brain- 716's [/COLOR]
joliecoeur13 is online now        Reply With Quote
Old 10-11-2011, 09:12 AM   #6
BaconRaygun
I use a gram scale, 100 x .01...
AMA# 977012
Old 10-11-2011, 09:29 AM   #7
Inverse
I use a homemade magnetic balancer. Works a charm.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
