Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > 330X
330X Discussion and support of the Gaui Hurricane 330X QuadCopter
Old 09-23-2011, 12:11 PM   #1
Full Montee
Default 25 Minute Flight Time?
I'm looking for a recommendation on gear needed to keep either a 330X or 500X in the air for 25 minutes with a GoPro HD.
I'm thinking the 500X may be the better choice as it has a higher load capability that'd probably be needed for the battery to attain that flight time.
Experiences, thoughts?
Robert "Full" Montee | Team Synergy | Team Futaba | Citizen 13
Full Montee is offline        Reply With Quote
Old 09-24-2011, 12:44 PM   #2
brent.downey
Hi Full,
I have a 330X-S and I just did a test flight with GOPRO (no case just camera) mounted to the top.
Battery was a fully charged 2200mah 3S Eflight. Flight time recorded in the video was 11:21 seconds
and it had lots of power left.
I charged the battery after the flight and it stopped at about 1500mah leaving 700mah unused.
I probably could have gotten a few more minutes out of it without harming the battery.
Hope this helps.
Brent
brent.downey is offline        Reply With Quote
Old 09-24-2011, 01:04 PM   #3
Full Montee
Leaving 20% capacity would be 1760mah. Sounds like you could do a 12 minute flight.
Could the 330xs carry all that with a 6000mah 3s battery?
Old 09-24-2011, 10:52 PM   #4
Nicecrash
I'm using 3X Zippy Flightmax 2100mAh 3S with total weight of 197g x3 = 591g and it flies fine. Without FPV camera, i think 6000mA will have no issue on take off .May be 10' prop can give some more lift.
NC
Nicecrash is offline        Reply With Quote
Old 09-24-2011, 11:49 PM   #5
Full Montee
NC, what flight time are you getting?
Old 09-28-2011, 08:58 PM   #6
scientist
Go for 3S 5000mAh
Close to 25Minutes.
Rave450 x Velocity50 x Logo600SE x ArducopterMulti.x Gaui 330X x Mikrokopter Hexa x MultiWii x XAirCraft X650V8
scientist is offline        Reply With Quote
Old 09-28-2011, 10:29 PM   #7
Nicecrash
Getting bored to test it on hover, 28' .
NC
