Go Back   HeliFreak > R/C Helicopter Support > SAB Heli Division 630/700/770
SAB Heli Division 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 01-27-2012, 04:01 AM   #101
worldofmaya
I always recommend reading Henseleits TDR manual, he has all values in there. This extreme-rpm type of flying is something typical for those let's say international- or Align-style machines with their "interesting" way of thinking about what a governor should do. And don't speak about their interesting head-to-tail ratio...
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-DJI-F550
worldofmaya is offline        Reply With Quote
Old 01-27-2012, 12:37 PM   #102
rexxigpilot
What is the head to tail gear ratio of the Goblin BTW? I know the TDR was designed to turn the tail fast at low headspeed (high ratio), but I doubt the Goblin is quite the same. The 110mm tail blades tell me it is a low ratio. Although didn't Bert mention in his SmackTalk video that the Goblin tail is OK at low headspeeds?
rexxigpilot is offline        Reply With Quote
Old 02-05-2012, 10:34 AM   #103
popokatepetl
Here's my shopping list:
Futaba BLS255HV - cyclic
Futaba BLS256HV - tail
Futaba CGY750 - flybarless
Futaba R6203SB - reciever
Power JIVE 120+
WR Hercules super BEC @ 8.4V
Xera 4035/2.5Y 480KV (need 26t or 28t pinion)
12S 5000mAh 45C batteries
About to build a rocket
popokatepetl is offline        Reply With Quote
Old 02-05-2012, 10:52 AM   #104
popokatepetl
I think the main rotor/tail ratio is 4.77?
Old 02-05-2012, 11:06 AM   #105
Yoda DK
i think it's 115mm tail blades. you can buy a smaller pinion and another pully for the tail. then you can run low headspeeds
Yoda DK is offline        Reply With Quote
Old 02-05-2012, 12:06 PM   #106
rexxigpilot
You are correct Yoda. The only question is why only a 4% change in tail rotor gearing going from the stock Z27 tail pulley to the optional Z26? The Z26 is for use with headspeeds below 2100. If I run 1800 headspeed, that's 14% less main rotor headspeed than at 2100. Seems like even smaller tail pulleys are needed.
Old 02-05-2012, 12:24 PM   #107
popokatepetl
You'll be safe with 115mm blades even at 1700RPM!
I think you don't need to think about it. It will work for sure even with stock pulley.
Old 02-05-2012, 12:39 PM   #108
OnTheSnap
The stock t/g ratio must be >4. Anyone know the real number?
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e
HeliDirect, Team iKon, GrandRC
OnTheSnap is offline        Reply With Quote
Old 02-05-2012, 12:39 PM   #109
alexvan
There is a recommendation in the manual in case of head-speed < 2000 rpm. I have the same concern.
alexvan is offline        Reply With Quote
Old 02-05-2012, 12:49 PM   #110
rexxigpilot
I do recall reading that the tail blades were to be 110mm at some point. I assume going to the 115mm was to address the tail authority concern at lower headspeeds.
Old 02-05-2012, 12:58 PM   #111
OnTheSnap
Bert's video shows really good tail hold at 1700RPM. So unless they changed the t/g ratio last minute, I would think we're good to go with the 115mm tail blades.
On the other hand, I plan on running 2200RPM, and running the tail as slow as possible for good tail hold will really improve tail belt life. So if the stock t/g ratio is something crazy like 4.8-5.0, I think the high RPM guys are going to see a pretty short life for the belt.
Old 02-05-2012, 01:32 PM   #112
felborn
I though you could configure the tail RPM by chaning the pully system, was that just wishfull thinking on my part?
felborn is offline        Reply With Quote
Old 02-05-2012, 01:55 PM   #113
popokatepetl
I think there's only one tail pulley available.
You'll be 100% safe with 115mm blades even at 1600RPM. Don't worry.
Old 02-05-2012, 01:56 PM   #114
alexvan
No, there are two pulleys available.
Old 02-05-2012, 02:03 PM   #115
popokatepetl
Yes you are right. There is 26t as an option and 27t which is in the kit.
Old 02-05-2012, 02:11 PM   #116
alexvan
All us are having the opportunity to in-depth study the Goblin manual.
Old 02-05-2012, 02:29 PM   #117
popokatepetl
Actually I don't understand why we should bother with that. I'm quite sure that the tail will work from 1600 up to the 2200RPM with default pulley.
Old 02-05-2012, 02:50 PM   #118
worldofmaya
The tail should be no problem even at lower rpms because the main to tail ratio is pretty good.
-Klaus
Old 02-05-2012, 03:00 PM   #119
OnTheSnap
-Klaus
But what is it?
Old 02-05-2012, 03:37 PM   #120
Yoda DK
plan for me is to run idle1 1850 and idle2 1950. so i'll order 20t pinion and pully H0049-s then i should be ok running low headspeeds i think. would like to try to go below 1700rpm if that is possible
