| Airtronics Radios Airtronics Radios Support |
Sunday when I turned on my 10G with the display button I got a low battery signal even though I had just finished charging it. If I turn it on with the power switch and it is transmitting the voltage reads correctly and matches the blancer on my charger. What is going on???
What battery do you have in it?
TM |
I am using a 2s TP lipo.
Verify that the pack connector is securely plugged in. Could be a faulty connection.
TM |
Thanks I will double check that. Could that result in a correct voltage reading in the transmitt mode? I would think that it would read incorrectly in both modes. But if I knew for sure I wouldn't be asking would I.
#6 |
If it doesn't work right, we can get it fixed for you, quickly.
TM |
#7 |
I have been busy but I checked the connection in the radio and it seems ok. The voltage in the display mode starts out about 7.2 volts then slowy drops until the alarm goes off. I am going out of town for a few days, but I will check it with the stock battery when I get back. The voltage in the normal, transmitt mode still seems to be reading and operating correctly. If the stock battery shows the same symptoms I will send it in for a checkup.
#8 |
Same problem here but I'm to far away (in Asia) could anybody show how to fix it? Can it be fix by instaling firmware again using USB cable? Please help
Team Compass - Atom 500 - Knight 50 3D - Odin 90 - Avant Aurora |
