| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
#21 |
All excellent points here from everyone. I don't think anyone is disputing all the effects and variables at play on a heli. In fact, this is definitely a big part of what makes this hobby so much fun for me.
Anyone have a data logger for power consumption and altitude meter on the heli? You could get some info on overall power used vs power done. Compare upright vs inverted climbouts and that should be a very good comparison of aerodynamic efficiency.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
#22 | |
Wlfk There are 10s of variables involved in the question, most of which interact. But I picked the canopy question because it is easier for most people to understand, and they seem to focus on it as a cause. The data I presented took some effort to calculate. If you have evidence to suggest the finding is incorrect, Id like to see it. The reality is, air flowing over a stock canopy from the bottom (i.e. in an inverted hover) creates more drag than it does when it flows over the top of the canopy (upright hover). In a hover, the airspeed over the canopy in upright hover is approx 2x higher than inverted, and drag is a function of airspeed squared. So, if you do the math, inverted hover for a stock canopy is more efficient; it has a higher drag coefficient, but is seeing slower air. But as the machine accelerates inverted, the drag advantage drops rapidly, because the difference is airspeed is no longer 2/1. By the time you reach 8.1mph, the airspeed ratio is 1.45/1, which is where the drag becomes a break-even. Above that speed, the drag becomes a net negative inverted. Just an sort of an interesting visual, have a look at this vid: Aside from it being a cool video with a great soundtrack and a very smooth pilot, there are sections where the canopy has collected rain. You will see in those sections the surface flow pattern over the canopy. Look at 3:30 for example, and on departure, you will see how dramatically the water droplets change from a vertical path to horizontal as he accelerates. That shows you the velocity components in play- where even at a forward airspeed of 10-15 mph, the droplets are nearly horizontal. There is just not that much wash on the canopy, and it is far less for our models, which operate MUCH lower disc loading.
"The problem with quotes found on the internet is you have no way of confirming their authenticity." - Abraham Lincoln |
#23 | |
Well, the original question is 'which is faster', not which is more efficient. Not necessarily the same This really needs a wind tunnel with proper high speed cams and all that...
#24 |
True the original was 'which is faster' but that was under the presumption that the head was setup symmetrically and slop was not a factor. I'm 100% sure that there are all the other variables at play such as described by yourself and others.
However, when it comes to 250 size helis I feel it is a slop/asymmetrical pitch issue. Then, when it comes to pros it is the effect of ground push-off and the good old 'cool factor'... IMHO On a small heli when pitch is setup using a gauge the main shaft/head is pushed downwards which biases the slop to falsely show additional positive pitch. Additionally, the pitch gauge is typically not balanced on small blades well. This buts weight typically on the trailing edge of the blades.... biasing the pitch additionally to the positive side. End result is the in reality if for example you think you have a -10,0,+10 setup you in actuality have -11,-1,+9..... this makes for a faster inverted climbout.
#25 |
Ground effect exists practically only for a rotor diameter’s distance from the ground, and even then, only adds about 15% efficiency. The rotor diameter/ground effect rule is independent of upright/inverted; it is simply disc to ground.
#26 | |||
If you imagine a ducted fan, you'll find that the airflow in front of the fan and the airflow behind it aren't terribly different. It doesn't make sense to talk about half the acceleration happening in front of the fan, and half behind. There'll be a small difference due to compressibility, but it won't be anything like 1/2 ratio in air velocities. The reason a rotor has a higher velocity beneath the rotorblades is that, if you imagine it as a 'virtual' ducted fan, the shape of the duct would be more 'conical' with the air outlet significantly smaller than the air inlet. In other words, a larger volume of air is being accelerated to a lower speed above the rotor, and a lower volume of air is being accelerated to a higher speed below the rotor. There's a figure illustrating this for tail rotors on Leishman, pg 318: http://books.google.com/books?id=nMV...pusher&f=false The difference in efficiency for a pusher or tractor tail rotor seems to be about 6%, but this depends partly on the area of the tailfin, so obviously won't translate directly to the performance of a main rotor. And another figure showing the vena contracta here, more clearly: http://www.aerospaceweb.org/question/aerodynamics/rotor/rotor.jpg Quote:
#27 |
You can get the rotor closer to the ground when inverted... no heli frame getting in the way.
If anyone wants to do a simple experiment to see how much slop there is: Put a pitch gauge on a 250 or other small heli. See what pitch you have upright... then simple hold heli upside down and see how off the gauge is.... it'll easily be more than 1 degree on a small heli.
#28 |
This would only work if you had the blades spinning at flight RPM, as you need the load to see where everything will sit. And I dont know about your 250 but if my 200 had that much slop in the links they would be needing replacement. Working the blade grips by hand i can barely move them at all, so not much slop there.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#29 |
True you need to be in flight to truly see what is up. I don't have a 250... but on my 450 I can get maybe 0.5 degrees of movement by hand. 250's I've seen generally are sloppy ... you see it in the tail as well.
#30 | |||
For Cd, you will need to find a reference. Mine is simulated in CFD and confirmed in a tunnel. But that is just for my canopy- there could be massive deltas depending on the design, if there are holes under the canopy, etc.
#31 | |||
Let's say you have two otherwise identical helicopters, one with a rotor mast of 10cm and one with a rotor mast of 20cm... Hover them first of all upright, then inverted, and measure the velocity of the air passing the canopy in each case... The ratio will be higher for the 20cm mast than for the 10cm mast, therefore it's not a constant. To take the argument further, imagine measuring the velocity immediately above and below the rotor... It will be identical (because acceleration, by definition, is not instantaneous in either time or space). This is why I'm arguing that you can't be certain that the ratio will be 1:2 without doing a lot more work or simulation, than simply arguing that half the acceleration happens above the disc, and half below. Quote:
I'm fairly confident in arguing that the ratio of the airspeed passing the canopy when inverted:upright is not fixed. However, your argument about CdA would still make sense if the velocity ratio can't exceed a particular limit of 1:2. I can see that the ratio of the vena contracta to the area of the rotor disc may be fixed and relatively calculable. However, I don't immediately see why there should be a similar lower limit on the velocity of the air above the rotor disc? At some distance, it will sooner or later approach zero (this isn't apparent on your link, presumably because it's talking about a propeller that will be moving through still air). In other words, I don't immediately see that the ratio can't be larger than 1:2, though I'm open to education and I'll admit I would have probably guesstimated the ratio to be less. Quote:
#32 | ||
The wake contraction happens some distance from the rotor plane because air is still accelerating. So, while for a 450 rotor (call it 28” diameter) the inflow velocity 10cm above the disc on the inflow side is not quite X, the outflow velocity 10cm below the rotor is not quite 2X. One can postulate all kinds of arguments about these flows. For example, inflow is non-directional, and outflow is. Conversely, the upright variation has much of the canopy within the grip area, where very little acceleration happens. The ratio will likely not be 2:1- it is very dependent on the proximity of the canopy to the rotor, and the rotor diameter, etc. None of this is particularly specific- it can't be, since there are huge variations in machine design, head speeds, etc. Even if it is 3:1, the breakeven on drag increases to just 15mph. Above that speed, the inverted canopy is more draggy. By the time the machine reaches 27mph, the inverted canopy is generating 30% more drag than it would upright in the wash. Keep in mind, for benefit of the doubt my calcs are assuming the canopy is seeing the entire average velocity (2X). It isn’t- it is seeing less than half that due to its position in the slower velocity flow core. In that scenario, the breakeven (even assuming a 3:1 flow delta) is at 6.8mph… Yes- I meant area, was typing too fast. Thanks for the correction Quote:
I would be surprised also. No, I don’t work for Align, and I would suggest based on designs I have seen that most RC helicopter manufacturers do not employ aerodynamicists…
#33 | |
Likewise, never sure whether going finless would actually make the helicopter aerodynamically neutral given that you also have a huge canopy up at the front and a tailrotor at the back... Haven't got the time or the skills to work it out so I'd be interested if you have any ideas. |
#34 |
Right- define the optimization criteria. For most, it is ‘how cool does it look?’.
I think that you will find that, for all the marketing smoke and mirrors, this hobby is not very scientific. There is a lot of inertia in designs, and Id bet $1 that there is no comprehensive test data from any major blade supplier on their blades’ dynamic aero characteristics. We can barely get base stats on our servos (i.e. show me official manufacturer specs on voltage vs torque vs angular rate). How about charts defining an ESC’s capabilities in various corner conditions (i.e. ability to react to a load transient), or its power efficiency into some standard motor across RPM/load. In the absence of this data, it seems there are a whole lot of uncontrolled variables involved…
