Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 200
Hurricane 200 Discussion and support of the Gaui Hurricane 200
Old 10-14-2011, 12:42 PM   #21
grumpy42
Originally Posted by jmcdonald View Post
whoops, yeah I have that washer and it does extend a couple mm out but seems like it should be longer and extend into the bearings.
That's just the design of the original grips/spindle. The spindle "butts up" against the grips bearing (with a washer in between). That is why I thought that something might not be "seating" properly causing the grip not sit straight on the shaft.
Anyway, if you don't want to abandon the Gaui, the new style grips are an easy upgrade. They are a more conventional design with the shaft extending through the bearings.
grumpy42 is offline        Reply With Quote
Old 10-14-2011, 04:44 PM   #22
jmcdonald
Thanks, are you saying the new style grips come with an upgraded/longer shaft? Or do you buy it separate?
jmcdonald is online now        Reply With Quote
Old 10-14-2011, 05:09 PM   #23
grumpy42
Yes, the grips come with ONE shaft. EmpireRC, in their infinite wisdom, neglected to import the spindle shaft packs (203853), so if you want extra spindle shafts you will need to get them from overseas.
Old 10-14-2011, 05:52 PM   #24
jmcdonald
Nice, right before I read this, I ordered a couple things from Empire RC including the new grips. In the order comments, I made somewhat of a sarcastic comment regarding them not carrying the spindles separately-something in the order of: "Are you suggesting anytime the spindle gets bent, we should order a new set of blade grips to go with it. That would be ridic." Genius
Old 10-16-2011, 10:42 AM   #25
nexgen
im pretty sure these would work:
HURRICANE 200 FES SPINDLES
G-203854
$3.50
GAUI Field RepbeastXTeam Empire Hobby
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
nexgen is offline        Reply With Quote
Old 10-16-2011, 01:19 PM   #26
dynodude
G-203854
$3.50
The flybar head block is narrower then the FBL. They would be to long.
My Dawgz Got Madd Skillzz!
Heli #1:Gaui 200V?/FBL/BeastX V2.05/Gaui 5600/CC25/5065 MG's/DS09 GMD/Spektrum Sat.
Heli #2:Gaui 200V?/FBL/Gaui 5600/CC 25 ESC/65 MG's/BeastX V3.08/DS09 GMD/Spektrum Sat.
dynodude is online now        Reply With Quote
Old 10-16-2011, 08:22 PM   #27
jmcdonald
Yep, the FES spindles don't work. Tried them about 6 months ago.
Old 10-17-2011, 02:37 PM   #28
nexgen
aah, ok. I wonder if you could add a spacer to push the grips outward slightly : just thinking of how you could work with whats available now
Old 10-17-2011, 07:13 PM   #29
jmcdonald
Appreciate your concern. Ordered the updated grips/spindle from Empire RC couple days ago.
Tags
blowout, gyro, spartan, tail, wag
