Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Old 10-02-2011, 02:54 AM   #1
norstaroption
Default Digital Trim to Adjust Gyro Gain
How can I assign the rudder trim to adjust gyro gain of Futaba 8FGHS?
Synergy E5 Jive 100LV NEO
ATOM 500 YGE120 NEO
Nano QX 3D
norstaroption is offline        Reply With Quote
Old 10-02-2011, 03:22 PM   #2
Steve Evans
Go into the rudder gyro menu and under the "Fine Tuning" section change the "--" to T4. Then wind the Tuning as negative as you can. Now play around with the trim and observe the effect on the resulting rate in "()".
Then be sure to turn off the T4 effect on rudder. In the Function menu change the trim on Ch 4, RUD to "--".
Don't forget to check that the trim is affected by flight modes as you require.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 10-03-2011, 03:22 AM   #3
boltor
Great idea. Only had my 8FG for a few weeks. I assume this is better than using the dials as this way it is set per model, whereas the dials would be fixed for all models (unless you remembered to change them).
Compass 6HV FBL | Stock Motor | CC 80HV Ice2 ESC, gov via SK720 | SK-720 FBL & PowerBus
MSH Protos 500 | Scorpion 3026-880 | CC 75A Ice Lite ESC, gov via SK720 | SK-720
Other: Spektrum DX9 | iCharger 4010 Duo
boltor is offline        Reply With Quote
