| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hi, I have a problem with my Trex 250,
When I hit the throttle on my remote (Turniny 9X) Then run the engine very badly, it is just around itself .. You can check the video I've uploaded. Have moved the engine so it has no resistance from the gearing. Is there anyone who has had the same problem? |
Could be a bad esc...also check to see if you have soft start enabled on your esc
check your bullet connectors, wiggle each of them while throttle is up.
The more I learn the more I realize I don't know To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 2x T-Rex 500, T-Rex 250, 2x MCPX AMA#965241 Last edited by TeeJayShelton; 10-02-2011 at 12:25 PM.. Reason: typo |
I have solved the problem! There has been something with ESC.
Have replaced it with another one and now it just works! |
