Old 04-26-2007, 02:28 PM   #1
MikeWz
Default Set-ups?
Just wondering what set-ups you're going to use on this helicopter as far as motor/pipe/blades/radio gear/BEC/Regulator....
This is going to be my first nitro bird...and the first one I'm flying since last summer so just looking to get some info together so I can get a good set-up. Thanks
MikeWz is offline        Reply With Quote
Old 04-26-2007, 06:09 PM   #2
Helifan
I am going to transfer equipment from one of my R50 to it.
Hyper
MP2Q
TT600
149DP
S9252
GY601
TJ Pro
s9254 (throttle)
Expert2700
Helifan is offline        Reply With Quote
Old 04-26-2007, 07:49 PM   #3
aamwood
What I have prepared for this bird is :
Gyro Futaba 611
9451 Servos ( for all include throttle )
Rev Max Gov
149 DP
Assuming the Head is the same as the electric one, I have prepared all the upgrades for the rotor head.
aamwood is offline        Reply With Quote
Old 04-26-2007, 11:33 PM   #4
MikeWz
What will you be using as an RX pack? If a regulator/step-down of somekind is needed, what will you be using? This is what I'm most unsure about. Thanks for the suggestions so far.
Old 04-27-2007, 01:48 PM   #5
wcc963
What i plan to get when its released:
OS 50 Hyper
3x HS-6975's on cyclic
Futaba S3001 on throttle
Logitec 6100T/LTG 6100G
CY Muscle Pipe\
V-Paddles
V-Tailblades
CY 600mm Main blades
futaba GV-1
TP 3400 2S Rx pack
and i already have a DX7
wcc963 is offline        Reply With Quote
Old 04-27-2007, 03:39 PM   #6
Funky
The electronics on my 30 are being moved to my Titan. My 30 will most likely be retired to be future crash parts for the Titan.... although I like the long run times so I might set up the 30 with some cheap electronics to keep it in the air. I will be pulling parts from my Titan for the new 600. My setup will be:
3-9252 cyclic servos
611 gyro w/9256
9254 throttle servo
Hyper 50 with Muscle pipe (although I may try the Hatori)
Multigov
V-Blades and Radix main blades
95mm V-blades for the tail
3600 4.8 volt Sanyo Nimh RX pack
More helis than brains
Funky is offline        Reply With Quote
Old 04-28-2007, 12:21 AM   #7
MICHAEL
OS 50 hyper with JK hatori or muscle pipe
Arizona reg with FP lipo
611 gyro w/ servo it comes with
3x 9351's
1x 9451 for throttle
V-mains, tails and paddles
DX7
This is the set-up i will run but i think it may take a few months.
Synergy N9
T-Rex 600CF
T-Rex 450SE Black
T-Rex 450SE Silver
MICHAEL is offline        Reply With Quote
Old 04-28-2007, 01:02 AM   #8
MikeWz
Here's what I'm planning on running for now. Does it sound like a solid set-up?
DX7 (untill the new 9303 comes out. Can't wait until July to fly though)
OS 50 Hyper with Haitori JK muffler (maybe MP2 if I can't cough up the cash)
3 9252s for the swash
6100t/6100g for the tail
S3001 for throttle
Radix or Align blades head and tail
Duralite 4300 7.4v rx pack
Arizona Reg (or duralite reg)
TJ Pro
Old 04-30-2007, 03:00 PM   #9
erniefritz
get the duralite 6.0V reg and the duralite tail voltage stepdown for the tail servo... they work great and have them on my Stratus...
erniefritz is offline        Reply With Quote
Old 05-01-2007, 07:13 AM   #10
rhino
here is my setup
Os 50 hyper
MP2 (Changint to Hatori
9252's on A model, 9451's on B model.
Align reg
611
9252 on Throttle
CSM revlock 20
SAB's at the moment,V-blades to come.
This machine is awesome and flies like a 90 sized machine. You wont be disapointed.
Tdrex
rhino is offline        Reply With Quote
Old 05-01-2007, 08:12 AM   #11
MikeWz
Rhino - I'm jealous man, already have yours. Still just on "the list" here.
Which do you prefer, 9252s or 9451s?
Old 05-02-2007, 01:42 PM   #12
manu2604
please excuse the ignorance , but, why do you guys need all those beefy servos, 9451, 9254,etc on the throttle?
manu2604 is offline        Reply With Quote
Old 05-02-2007, 05:34 PM   #13
dacostad
I am a beginner with Helicopters and to RC. I currently have a Trex 450 and a 600CF (which I will be putting in a scale fuselage) and will be getting a Nitro Pro as soon as they are available.
I know nothing about using a Nitro and would be grateful for some advice on what else I will need to buy with recommendations on makes/models as well as some basics on how to start (and stop), how to operate in terms of any tuning/ maintenance/ fueling etc etc.
Thanks for any help.
David
dacostad is offline        Reply With Quote
Old 05-02-2007, 06:31 PM   #14
rhino
Manu, the beefy servo's arent required on the throttle, it was just what I had laying around. I will be fitting the Futaba Mini digital servo once its sent to me.
Tdrex
Old 05-02-2007, 07:32 PM   #15
aamwood
In fact, if you are planning to use a governor , I think you need to have the same type and speed for all the servoes. The reason is allowing the throttle to have the same speed with pitch. If the servo is slow, then the throttle is always left behind. That's my thought. But I agree, if I am not planning to use governor than I can use different type of servo for the throttle.
Old 05-02-2007, 08:03 PM   #16
aamwood
Rhino, is that your Trex 600 N ? How come you can get it so fast ?
What is included in the box ?
Old 05-02-2007, 09:45 PM   #17
rhino
Yeah I have had my 600's for about 2 weeks, I am an ALIGN rep and will be using these machines at 3DM, so thats why the preproduction versions.
I received the pro versions,so you get the CF frames and torrque tube. BEC,Engine and RX Lipo will be included in the Combo versions.
Tdrex
Old 05-03-2007, 12:15 AM   #18
medflight
rhino,
Can you tell much difference between the 9252's and the 9451's?
medflight is offline        Reply With Quote
Old 05-03-2007, 12:28 AM   #19
rhino
To be honest at this stage I can not. I think 3 x 9451's on a 50 sized machine is a bit excessive. I am running the 9252's at 6v as well as the 9451's, so this evens the specs out a bit more.
Cheers,
Ryan
Tdrex
Old 05-03-2007, 03:39 AM   #20
tiranosaurus rex
Yo rhino,
How are you running 6V on the servos but still have the 611?
Have you just chucked the ALIGN step-down on between the rx and gyro/servo?
cheers,
Caleb
MA Fury Extreme:
OS.90 C-spec | MP2 | GV-1 | 9252's | GY611/9256 | RS770s | 4.8v 3600mah subC | V 690's / V 105 tails / V paddles
ALIGN T-REX 600 N (Up next)
OS.50SX-h Hyper | hatori 522 | 9252's | GY611/9256 | RS770s | 4.8v 3600mah subC | Radix 600's | NHP 95mm tails
JR X2610 trany
Reflex XTR sim
TakeoffandLand
Coolpower
'Don't be dumb...use the sim'
tiranosaurus rex is offline        Reply With Quote
