Old 10-03-2011, 11:58 AM   #1
Stykz
Default Moror shutdown
Hi guys
I am after a bit of advise, flying my heli for the first time yesterday everything was going fine just doing some loops and rolls started doing some tick tocs and the motor just shut down so it dropped like a stone from about 40 feet to my amazement nothing broke or bent so i flew on.
i then changed to a new pack loops and rolls again no problem till i went into a inverted hover and bam the motor shut down again as soon as it hit the ground the motor started again but it snapped the belt and the pinnion was in two pieces.
any ideas
cheers
Stykz is offline        Reply With Quote
Old 10-04-2011, 01:16 AM   #2
baui2000
Check your motor plugs.
I had a similar issue caused by my DX8 transmitter, had to send it in twice to get it fixed.
Tom
Outrage Fusion 50
HC3-SX, A50-10L Turnado, CC ICE2 120HV, WR Super BEC, DH20-FTD / MKS HBL980
Prôtos Mini FBL Stretch 4S vBar 5.3Pro, MSH 2010kV, YGE-60A, MKS DS95 / DS95i
baui2000 is online now        Reply With Quote
Old 10-04-2011, 02:39 AM   #3
ziper_it
Also, what receiver are you using? There have been similar issues with frsky rx.
ziper_it is offline        Reply With Quote
Old 10-04-2011, 04:58 AM   #4
macem
... check th other plugs (lipo, esc...) ...
macem is offline        Reply With Quote
