Old 04-26-2007, 03:58 PM   #1
kenzkytralala
Default Problem with the swash plate (i've seen bobs videos)
Hi!
I've seen bobs videos, but I still have å problem.
I got a problem with my trex 450 XL CDE.
When I have the pitch stick on center I got 0degrees pitch and the paddles at level.
But when I go full positiv or full negativ I got too much elavator. Its too much so it dosnt help when I changes the end points.
What should I adjust? Something mekanic on the heli, or something with the servoarms, or something in the transmitter which is a futuba 6EXHP?
I'm a newbee
kenzkytralala is offline        Reply With Quote
Old 04-26-2007, 04:55 PM   #2
JayDBaltimore
Are all of your servo arms at 13mm? Or at least the same length? And are you using the exact same servo's? Do you have any end point adjustments on aileron and pitch?
JayDBaltimore is offline        Reply With Quote
