Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-06-2011, 03:38 PM   #1
johnahamelv
Default CC BEC Pro delivering inaccurate voltage
I just tested different voltage settings for my CC BEC Pro Rev2(1.03) running the Castle Link(3.411 software version). These are the results:
4.9v delivers 4.12v (very bad)
5.0v delivers 5.03v (right on the money)
5.1v delivers 5.16v (great)
5.3v delivers 4.49v (very bad)
5.4v delivers 4.62v (very bad)
5.5v delivers 5.53v (right on the money)
5.7v delivers 5.66v (very close)
5.8v delivers 4.97v (very bad)
5.9v delivers 5.10v (very bad)
6.0v delivers 6.01v (right on the money)
6.2v delivers 6.14v (very close)
6.3v delivers 5.48v (very bad)
6.4v delivers 5.60v (very bad)
6.5v delivers 6.51v (right on the money)
6.7v delivers 6.64v (very close)
6.8v delivers 5.96v (very bad)
6.9v delivers 6.08v (very bad)
7.0v delivers 7.00v (perfect)
7.5v delivers 7.50v (perfect)
8.0v delivers 7.98v (right on the money)
8.5v delivers 8.49v (right on the money)
9.0v delivers 8.91v (close)
10.0v delivers 9.89v (close)
10.5v delivers 10.39v (close)
11.0v delivers 10.87v (close)
11.5v delivers 11.38v (close)
This showed me that the BEC Pro is very accurate for the following voltages: 5.0v, 5.5v, 6.0v, 6.5v, 7.0v, 7.5v, 8.0v, and 8.5v. However, the voltages in between and outside these voltages can be off by as much as 0.84 volts lower than the set voltage.
I contacted Castle about this issue. I was told that my BEC Pro was working properly. The tech, Bernie, mentioned that they put their effort into making sure that the "standard" voltages are accurate, but they do not spend much time with the in-between voltages. He went on to mention that he and other techs have tried to remove those other "non-standard" voltage options from the software, but the bosses want to keep these non-functioning voltage settings in the software.
Considering this issue, I strongly recommend testing your BEC Pro voltage output with a digital multimeter before exposing your electronics to the BEC Pro.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is online now        Reply With Quote
Old 03-24-2012, 05:20 PM   #2
K2Freak
I'm running a pretty recent build and it is still happening. I was running 5.8v and getting 4.95 and getting worried really fast!
Thanks for posting this. It isn't an ideal situation, obviously, but it's great to know that what I see is "normal."
//edit - didn't notice where we were. Maybe this should move to the CC forum?
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 03-24-2012, 05:53 PM   #3
satgod
seems like getting off the .5 volt step is where it looses calibration and I can see that in a small unit using a ic for reg
I just run mine and 6v and i'm happy
why where you running at 5.8 anyway
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 03-27-2012, 02:17 PM   #4
03silver
"but the bosses want to keep these non-functioning voltage settings in the software"
That's so wrong on so many levels. Thanks Johnahamelv for sharing.
03silver is offline        Reply With Quote
Old 01-13-2013, 04:41 AM   #5
johnahamelv
It seems that the newer BEC Pro's deliver more accurate voltages when set to the non-standard voltages.
Old 01-13-2013, 11:22 AM   #6
Commodore8888
Does it say v2 on the casing?
Tempted to go hook mine up for curiosity's sake. Running it at six and only when I've loaded it pretty badly it sags about .3~.4v
Resident Mad Scientist
E5-S KDE 600XF / 600N 55HZ
450 Pro V3 / Mod 130x / mCPX BL
Mike D--AwesomeRC Hobbies
Commodore8888 is offline        Reply With Quote
Old 01-13-2013, 12:09 PM   #7
johnahamelv
All 4 of my BEC Pro's are V2. I did the original voltage test on my older two v2 BEC Pro's with the square case. I performed the recent voltage test on the v2 BEC Pro with the rounded case design, and have not retested the older BEC Pro's. I understand that Castle claims that all the v2 BEC Pro's have the same internal hardware despite looking different outside, but I am just posting voltage test results at the bench.
Older v2 BEC Pro with square.
Newer v2 BEC Pro with rounded design.
Name:	BEC Pro round.JPG
ID:	383481   Click image for larger version
Name:	BEC Pro square.jpg
Tags
bec, bec pro, castle, voltage
