Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 10-07-2011, 10:51 PM   #1
Thalios
Default Motor bearing replacement procedure
Thanks to Woody_99, we have a great tutorial on main motor replacement procedure.
Here's the link to the file.
Motor bearing replacement procedure!
Enjoy!
Thalios is offline        Reply With Quote
Old 10-25-2011, 08:59 PM   #2
Thalios
Great find by Gladiator.
http://www.helifreak.com/showthread....57#post3347557
Videos that shows how to do it!
Old 05-17-2012, 09:49 AM   #3
pdbrown
Default Tail gear/pulley assembly replacement
Hey everyone, great site with a ton of useful information. Any idea where I can get a video or description of how to remove and replace the Tail gear/pulley assembly? Can't seem to find this info anywhere, and it looks like a bear to replace.
Thanks!
pdbrown is offline        Reply With Quote
Old 05-17-2012, 11:19 AM   #4
Skidpad
Thanks!
This should work for you:
If you look at the "bladehelis" channel on YouTube, you can find the maintenance videos contained on the cd that came in the box with the 450 itself....plus all of their other videos.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote
Old 05-17-2012, 05:15 PM   #5
CyclicPete
Enjoy!
+1
I just used this guide, and now I have a spare motor waiting to go in, with some lovely
Boca Bearings in there
The stock bearings were a little tough to get out but came eventually
T-Rex 550E DFC
GOBLIN 570
Blade450 OUTRAGE QUARK
mCPX BL Goblin
CyclicPete is offline        Reply With Quote
Old 04-12-2013, 09:02 AM   #6
jrwalte
So when trying to place the C ring back on, I lost it in the carpet. I don't suppose I can find this C ring anywhere to purchase? A whole new motor for a part worth pennies stinks.
jrwalte is offline        Reply With Quote
Old 04-12-2013, 11:19 AM   #7
Skidpad
Default Re: Motor bearing replacement procedure
Stock motor - I bought some Traxxis e-clips that worked fine. I don't know the p/n off the top of my head, but I can look tonight.
I have quite a few, so if you can't find them locally, I'd be happy to send you some. No charge.
Old 04-12-2013, 11:46 AM   #8
jrwalte
Thanks for the offer!
I did find the c ring with a magnet thankfully.
Scratch that...while placing the clip on the needle nose and about to insert in the plastic bag, it popped off...no idea where it fell, unlike last time.
Finally. Found it again, and after 2 quality engineers assisting, it is finally back on. What seemed to work best was tweezers. Got it in the groove easily and then used the tweezer tip to push it on. Worked on the first try. Needle nose pliers were not working.
Old 04-12-2013, 01:07 PM   #9
jrwalte
Default Replacement C Ring
I measured the c ring for future reference.
Inner Dimension diameter is 2.5 mm (.098")
thickness is .38 mm (.0149")
This one should work. ID is .102 (.098 is within its tolerance range) and the thickness matches at .015.
http://www.mcmaster.com/#cadinlnord/98808a305/=mag46q
Old 04-17-2013, 07:19 PM   #10
R/C Mayhem
Hey, Blade..Can you make the circlip on the 220 motor smaller, Please.
Oh, and can you please magnetize it too?
Because helicopters...that's why.
MCX, MQX, MCPX, Blade 450 3D, Gaui 550. Turnigy 9X Spektrum DX6i.
R/C Mayhem is offline        Reply With Quote
Old 06-02-2013, 05:53 PM   #11
Diogenes
formerly koi-fish
What's the bearing size on the 440 motor? Is it a 3x7x3 like the 420?
Got a motor that I broke dwn today that you can move the inner race on the bottom bearing side to side with the shaft out
Shaft has marks but not grooves, which I think will be ok
/ 130x, 180cfx, 300x, 360cfx, X3, x3L, X4-II, Protos 380 (in transit), x5, Gob 500, Warp 360, 450x, forza 450ex, DX18, 07 Harley Road King/04 Sportster, Traxxas Summit/E-Revo/X-Maxx, Vaterra 67 Mustang Need Forza 450ex airframes and parts - thanks!
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is online now        Reply With Quote
Old 06-03-2013, 04:39 AM   #12
spykez
I think Coco66 miked it out for us on the 450x forums. You should be able to find it under advanced search if you look for his posts.
Still in exile. FML.
spykez is offline        Reply With Quote
Old 08-30-2013, 02:45 PM   #13
Barmo13
Default Motor Bearing
thats a good videos and instructional to change the blade 450 motor bearings BUT i have more problems . the bottom bearing is stock to the motor i heat it up and the top bearing leave with no problems...but the buttom one , is like mission impossible 5 !
some advice ??
thanks!
Barmo13 is offline        Reply With Quote
