Go Back   HeliFreak > R/C Helicopter Support > Kasama Helicopters and Upgrades
Kasama Helicopters and Upgrades Kasama Srimok 90 Helicopters and Upgrades Discussion
Old 10-13-2011, 12:59 PM   #1
nen77
Default Once again about vibration.
i'm making this post for a friend of mine . he stay away from any heli comunity, we visit from time to time.
i asked him to make a movie with the problem , and i sugested a solution, wich i wil not mention here - i wait to see if other offer same solution.
- set-up
-yamada engine
- radix blades
- torque tube upgrades.
-first time was equiped with os 91 engine , same vibration
replaced : clutch (all parts), new rotor head (he bought a new kit for spares)
video..
nen77 is offline        Reply With Quote
Old 10-13-2011, 01:44 PM   #2
hookmaker
Engine looks and sounds way too lean for me. My own YS engine vibrated a lot when lean - so much that my CGY750 FBL controller governor failed to work corectly.
/Henrik
Hookmaker
Kasama Srimok 90, Kasama Srimok 90E, JR Vibe 90 SG, JR Venture 90, JR Vibe 50 3D V-bar,
Bergen Intrepid Gasser, Vision-SX 90 (x 2)
MSH Protos "Monsterheli", HDX-450
hookmaker is offline        Reply With Quote
Old 10-13-2011, 03:33 PM   #3
Mercuriell
I'd agree with Henrik the engine too lean on that - have to check and double check pinion, engine mount, dampers as per manual and videos in Technical Tips. ALso check the tail from behind, if the blades are out of track it may be an offset tail rotor hub - a few escaped the factory not quite square (since remedied). Let us know how you go !
John
Mercuriell is offline        Reply With Quote
Old 10-13-2011, 03:51 PM   #4
nen77
thank's for fast answer , i will call my friend tomorow and i will tel him to open the middle ,glad that i asked , motor sound strange to me but my advice it was to lean the engine.
Old 10-13-2011, 04:38 PM   #5
HeliBenj
+1, this engine sounds very lean, also noticeable in the smoke flow that gets thinner as the RPM goes up.
I also had strange vibration with my former engine when running lean. The Srimok will make a bad tune and used engine bearing quite visible.
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote
Old 10-13-2011, 04:53 PM   #6
hookmaker
Yep, start by richening the middle needle.
/Henrik
Hookmaker
Old 10-14-2011, 02:38 AM   #7
thefrog
Something I've found is that my heli doesn't like certain headspeed - at 1800rpm it's all over the place. The vibe logs show low overall vibration but the way the heli shakes and twitches is quite horrible. I've ruled out tuning - this is with two different motors and setups from factory rich to spot on tune.
I run 1850 rpm in normal mode and 1930 in idle up. This is with an OS motor and 8.17 gear ratio.
thefrog is offline        Reply With Quote
Old 10-14-2011, 02:47 AM   #8
HeliBenj
No, I believe with the YS you should start with the mid in that condition. If hover smoothes out then check high
Ben
DX8, RF6
Old 10-14-2011, 09:09 AM   #9
XBOY
I have many times it was a perfect test
XBOY is offline        Reply With Quote
Old 10-14-2011, 01:59 PM   #10
nen77
i called my friend , and told him to open the needle's .after opening no improvement(4 click's on both needles)he says that the sound of lean engine is caused by the fuel with 15% nitro.
trick he also aplied from tehnical tips , new dampners to engine , and clutch dampners set-up after indication from video , new tail rotor (from spare kit ) new tail blades.
my opinion is that engine still can be to lean.
he also asked me to mention a thing : in video is not so well presented the vibration is more sideways in the head wich look's to be transmited to the tail...
Old 10-14-2011, 02:19 PM   #11
HeliBenj
Sorry not buying the 15% thing. I run 15% and none of my engines ever sounded like that (YS91SR, OS91HZ, HZ-R 3D).
Now maybe the engine is not the main reason here, but it can't be good either. Any idea of the temperature being run on the head?
Ben
DX8, RF6
Old 10-14-2011, 02:34 PM   #12
nen77
70-75 celsius 158-167 fahrenheit...
i can not advice in nitro engine's i crashed 3 os 91 engines .i have a topic in 700n area...found the couse after 1 year , 3 engines and 5 engine sets..caused by a molding problem of fuel tank.
also is hard to transmit your info to him, also he is tryng to "fix this problem" from a long time.
