Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 10-14-2011, 12:25 PM   #1
Stolla
Default rpm sensor
Ok at last received my jlog, havent unpacked yet but question i have, can the eagletree brushless rpm sensor be used on jlog for rpm.
or perhaps the hyperion phase sensor?
Old 10-14-2011, 12:44 PM   #2
GimpyGolden
Jlog measures RPM on it's own. Enter Gear Ratio and it calc Head Speed.
GimpyGolden is offline        Reply With Quote
Old 10-14-2011, 05:13 PM   #3
dl7uae
If you speak about the rpm of the motor behind the JIVE (and the derived rotor rpm): As said, you do not need an additional sensor.
If you intend to measure an external rpm on top like the rotor rpm during an AR: In principle every rpm sensor works because all these sensors generate a pulse. You only need to know how many pulses per revolution.
As long as we only want to measure items from/in the JIVE we do not need a physical sensor. All sensors are "virtual" ones in the JIVE.
Tom
Tom (j-log.eu)
dl7uae is offline        Reply With Quote
Old 10-15-2011, 12:21 AM   #4
Stolla
Wow that's impressive,guess i have to read the manual first!
Old 10-15-2011, 06:52 AM   #5
dl7uae
Check the Feature Matrix.
The manual is for version 3.1, old as the hills ..
Tom (j-log.eu)
