Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 08-10-2012, 07:23 AM   #101
bewing2
ive been using 2 FlightPower 4350 30c since i got my x5. No battery fence
Synergy E7 Vbar
Gaui x5 sk540 12s
Logo 400se Vbar
T-rex 450 Pro cgy750
bewing2 is offline        Reply With Quote
Old 08-11-2012, 12:21 PM   #102
Indydrt
hi i bought two of the 4000 glacier packs 30 c i could not fit them into my trex 600 efl pro .. so i will use them on my sport plane instead where they fit perfect .
my 3700 packs and 3300 packs fit great on my 600 the 700 i just ordered will be 5000 i guess but the 3 s pack i just bought for the 450 tested great yesterday by glacier was kool was its maiden flight no hard 3 d just mild flying cant do it anyway 3 d ..lol . so far so good .. got some pulse packs FINALLY oredered i hope also..
Always thanks for the help much appreciated makes the hobby alot easier and enjoyable
since i began flying in dec.2011
Indydrt is offline        Reply With Quote
Old 08-12-2012, 10:51 AM   #103
crf69
Glacier 30c pull harder than gensace 4000.
all the way to the end of my 4:00 flights.
fit great.
at my house in 1 day.
2 of my gensace starting leaking electrolyte.
dug a hole.
buried them.
R>I>P.
Buy good stuff then you never have to apologize to yourself for being an idiot....
Stay Inverted My Friends. Ryan Robinson 7hvGob7GauiX5Warp360SYNE5
"How high does it go?" Love that question.....
crf69 is online now        Reply With Quote
Old 08-13-2012, 12:51 AM   #104
Indydrt
Default glacier 2600
Flew 2600mah glacier other day on the pro 450 not to bad didnt get hot ..it was its maiden flight did one tic toc and then thought i better stay calm o a new battery so i did.. then i messed up and put it in a treee..lol went home got ladder pool net extened stick and a rope.. took bout 20 min boom was fine until it fell out of the tree from about 18 20 feet off ground and bent boom but not bad..oh well. got a new dfc pro 450 coming tues fix this one up and ebayer her.. will be perfect when done..Cheers
Old 08-24-2012, 02:21 PM   #105
Jmac 3D
Is anybody using Gens Ace 4000mAh 60c? They seemed like a decent deal for $84 so I picked up a few at Xheli.
Jmac 3D is offline        Reply With Quote
Old 08-24-2012, 02:53 PM   #106
Michaelinpr
It should fit fine. It has the same width and length as all the 6s GA lipos. Just the stacked cells are 4.5mm taller than my 25C 4000's.
FUSION 50 FBL, Scorp HKIII-4025-550/Scorp V 130,610's, V Bar/650
GAUI XB5-EXTREME 12s
, Scorp HK-4025-550/CC 80HV, 610's, V Bar/650
AleeS RUSH 750-KDE-700XF-395/YGE160HV, RJX FS0521HV's, IKON/RJX FS0521HV
Michaelinpr is online now        Reply With Quote
Old 08-24-2012, 09:30 PM   #107
gonepostal-
so im going to get a x5 in a month or so. id like to know what batt to get for my experience im only doing sport flying not to much 3d. id like to keep the cost down like the cheapest we can find because as i get more comfortable with the bird i will upgrade my batteries.
gonepostal- is offline        Reply With Quote
Old 08-25-2012, 08:48 AM   #108
mamartin
Just get GensAce. Either 3800mah 6s 25c or 4000mah 6s 25c
There cheap and they will do good all the way thru your growing pains. You won't be able to find a better battery for the price
iKON field Rep
GAUI NX4 with iKON, EDGE blades O.S.37
GAUI X5fes, iKON, Edge blades, CC 20amp BEC pro,
Align 600Npro, iKON, OS55HZ, Funkey B320 3D pipe, Radix Blades,
mamartin is offline        Reply With Quote
Old 08-25-2012, 08:53 AM   #109
caralmar
+1 they are great!
I do have a TP for sale if you're interested... Yes I know... I have no shame!
http://www.helifreak.com/showthread.php?t=447120
Rush 700 * Trex 700N x 2 * Trex 600Pro * Gaui NX4 - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote
Old 08-29-2012, 09:53 AM   #110
branflake12
Not sure if 20C is enough pack, but i heard that "SKY" was Gens Ace rebadged. This is on sale, so wondering if anyone is flying these:
http://www.hobbypartz.com/77p-sl4000-6s1p-20c-6666.html
I had good luck with "Blue" in the past, but find their C ratings "overstated"...so i doubt anyone is flying these:
http://www.hobbypartz.com/83p-4000mah-6s1p-222-20c.html
Thoughts?
Gaui X5!
Outrage G5 x2
Blade mCPX BL & Blade mQX
MultiWii Quadrotor
branflake12 is offline        Reply With Quote
Old 09-01-2012, 11:20 PM   #111
questerng
Default Simple mod to fit bigger battery
Hi,
I hope this is not been shared before.. If it's been post before.. Please ignore..But no harm posting again..
Long story short.. to fit a bigger battery
Picture tells the story..
Basically I raise the batt up with 6mm.. It should work with all X5..
I actually just tape it up to test fit.. Works great.. Clear the canopy at all 4 corner of the battery..
I had velcro on the original place.. so all I have to do it apply velco to both side of this platform and it's good to go..
Best part is it's easy to do and doesn't change anything from stock..
quest
Name:	bulldog 001 (Large).jpg
ID:	345490   Click image for larger version
Name:	bulldog 002 (Large).jpg
ID:	345491   Click image for larger version
Name:	bulldog 003 (Large).jpg
ID:	345492   Click image for larger version
Name:	bulldog 004 (Large).jpg
ID:	345493   Click image for larger version
Name:	bulldog 005 (Large).jpg
Name:	bulldog 006 (Large).jpg
ID:	345495   Click image for larger version
Name:	bulldog 007 (Large).jpg
ID:	345496   Click image for larger version
Name:	bulldog 008 (Large).jpg
ID:	345497   Click image for larger version
Name:	bulldog 009 (Large).jpg
ID:	345498   Click image for larger version
Name:	bulldog 010 (Large).jpg
Name:	bulldog 011 (Large).jpg
life is not the amount of breath you take, its the moment that take your breath away
questerng is offline        Reply With Quote
Old 09-02-2012, 11:01 AM   #112
questerng
A sneak peak after the mod with canopy on..
not the best picture.. But you can see from the shadow how it fit in there
I'm happy with the mod..
Name:	battery tray mod 002 (Large).png
ID:	345579   Click image for larger version
Name:	battery tray mod 003 (Large).jpg
Old 09-02-2012, 12:17 PM   #113
whippo
Just curious why have a battery fence if the batt is above it?
________________
Gaui - MSH - Scorpion - JR - Byron - OS - MKS - Savox - Edge - Spin - Rails - Lynx - Gensace - Skookum - KBDD
www.irchc.com
whippo is offline        Reply With Quote
Old 09-02-2012, 06:34 PM   #114
questerng
well.. it came with the set of frame stiffener while I was building it.. so I had it on.. after trying out the different battery.. I found that it doesn't fit the bigger batt..
Now it's off..
quest
Old 09-20-2012, 01:42 PM   #115
terrabit
Howdy yos!
How are Gens Ace packs holding up to longer term abuse in the x5? I've never had anything but good luck with them in other helis but, as I remember, the x5 is finiky about batteries. I killed several Turnigy and Hyperion packs in mine.
Thanks!
terrabit is offline        Reply With Quote
Old 09-20-2012, 07:15 PM   #116
Michaelinpr
Originally Posted by terrabit View Post
Howdy yos!
Thanks!
I have been using 3800 GA's (I have the mislabeled ones that are actually the 4000's) in my Fusion on 12s for over a year. I get 100-125 cycles a set with little sag until near the end of their life. I handed down some 20 and 30 cycle sets to my X5 and it is eating them for breakfast. Still flying well but the lipos really do not like how you can put the sticks into opposite corners on the radio and have the X5 asking for more.
I am really not happy with a 6s setup. I am coming from a 12s system with the fusion and I really like how kind it is to the power system over all. I am fairly close to going 12s for the X5 and then my lipos should last a long time.
Old 09-22-2012, 11:32 AM   #117
terrabit
You could go with a pair of 6s 2000 to 2500s in series. Finding an appropriately sized motor in the 400 to 450kV range could be a problem.
Old 09-22-2012, 11:45 AM   #118
Michaelinpr
Batteries have been harder to find than the motor. Motor will be a scorpion HK 4025-550 on 12 or 13 tooth pinion run with an CC 80 HV ESC.
Lipos have been difficult due the weight of the batteries combined with size.
Old 09-22-2012, 12:03 PM   #119
terrabit
That motor is also 52g heavier than the 4020-900kV motor. You'll be looking at a seriously nose heavy ship without a stretch.
Old 09-22-2012, 03:41 PM   #120
Michaelinpr
My bird is already stretched so I think it will accomadate the weight. Not 100% though.
