Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-16-2011, 09:24 AM   #1
929freak
Default Question about running 5 cell vs 6 cell
My current set-up is 170 main gear with 16pinion,my head speed calculator gives me 2450...
I'm switching to the 112 main slant tooth gear with a 13 pinion,if I run that gearing on 5 cell it's says headspeed of 2620. So 5 cells are cheaper and lighter,anyone have a reason this isn't a good idea?
I do have the pinion to use with the slant and 6 cell but was considering the 5 cell for a weight reduction.
All things being equal,if geared right performance wouldn't suffer on 5 cell would it?
Thanks guys!
929freak is offline        Reply With Quote
Old 10-16-2011, 11:25 AM   #2
GlobalHawk
If you wanna run 5s I suggest you get a 500. You're gonna kill that 5s battery!!!!! It'll puff after 1st flight.
Sent from my Samsung Galaxy S II using TapaTalk
That wasn't a crash....It was an acrobatic landing!
AMA# 927891
Trex 550E 12s Stretch BeastX, Trex 700E BeastX
GlobalHawk is online now        Reply With Quote
Old 10-16-2011, 03:55 PM   #3
Nko15
There is also a 12t slant pinion from the 700.
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, RCbearings.co.uk, Rapideyewear.co.uk
Nko15 is offline        Reply With Quote
Old 10-16-2011, 07:29 PM   #4
929freak
What am I missing? A 5000 MaH 40C 5 cell is good for how many amps? 200, correct? And a 6 cell 5000MaH 40C battery is also good for 200 amps,right? The only change is the voltage, 22.2 vs 18.5. So if geared correctly for the Kv of the motor shouldn't it work?
Or am I WAY off base here?
Old 10-16-2011, 07:34 PM   #5
krobinson103
The LHS owner is running a beam 600 on a 5s. He changed out the pinion and main gear to compensate for the decreased power. It flies well, but the best way to describe it is docile. Very stable and docile. He calls it boring.
krobinson103 is offline        Reply With Quote
Old 10-16-2011, 07:38 PM   #6
929freak
Thanks Krobinson...I just can't figure why....amp draw is amp draw,and all things being equal if geared accordingly it seems like it should fly the same...or better with the weight reduction..
I'm pullin' my hair out here!!!!
Old 10-16-2011, 11:41 PM   #7
chakotay
Power is (voltage x current) so by going to 5s battery, you will lose power or increase the current draw (please don't take the C rating too seriously, there's a lot of marketing in that number, most importantly don't expect to be able to pull 200 continuous Amps out of a 40C battery!).
That being said, this helicopter is a very versatile machine. I can run through a pack (6s by the way) in 4 minutes or in 8 minutes depending on headspeed, blade length, and flying style. If you go to 5s, you just have to expect less power and make sure that you won't over amp it. It's all just common sense really - run lower headspeed (mine is a great sport flier at 1900-2000 RPM) and shorter blades (the stock 520's are not bad), keep the weight down if possible etc. I think it's doable. Good luck!
Kontronik - the most commonly misspelled RC heli brand name
Fusuno - the runner-up
chakotay is offline        Reply With Quote
Old 10-19-2011, 04:00 PM   #8
Chris DeSain
Default correct the wattage is lower on the 5C
18.5v x 200A = max watts 3700
22.2V x 200A = Max watts 4400
So the load voltage drop will be greater on the 5S than the 6S
There is more to it also but your not going to get equal power at the same amp load or even a greater amp draw on the 5S.
You can gear it like it should be equal but it will not be. If you are running way below spec of the batts they will be closer but when the pack is loaded it will be noticable.
Century Heli Rep
Magnum Fuels Rep
Magnum Energy (you have to try them !)
Chris DeSain is offline        Reply With Quote
Old 10-19-2011, 11:21 PM   #9
Wynn1427
I always run the calculation based on the motor output.
Motor output watts / Voltage = Amp Draw
Stock 600mx it will be
Cont. = 2000 / 22.2 = 90amp
Peak = 3000 / 22.2 = 135amp
Now on 5s
Cont. = 2000 / 18.5 = 108amp
Peak = 3000 / 18.5 = 162amp
Saving on weight is a good thing but at the expense of two more critical items of flight time and stress on electronics is the reason to not go with a 5s. Going to a 5s setup could decrease flight time by up to (1 - (90 / 108)) = 17%. And with only a weight savings of maybe 140g on a 2800g+ setup, probably won't even notice it is gone.
Take a look at my post here in regards to the actual stress on lipos. Even though they both have the same stated amp draw one is more stressed and results in a lower voltage under load.
Wynn
T-Rex 550 FBL
rcparts-finder.com...an online database to find your parts in stock at various online stores...
Wynn1427 is online now        Reply With Quote
Old 10-20-2011, 07:39 AM   #10
jonp
Now on 5s
Wynn
What an excellent, clear and concise reply to a good question.
T-Rex 550E V2 / DS-610 / GY401 / 620 / CC ICE 100
T-Rex 600 ESP / DS-610 / GY401 / 9254 / CC ICE 100
T-Rex 700E F3C / DS-610 / GY520 / 650 /CC ICE 2 HV 120
jonp is offline        Reply With Quote
Old 10-26-2011, 02:39 AM   #11
929freak
Wynn,thank you for the clear answer...it really helped
Jon,thanks for the "good question" comment...I felt a little embarrassed to be asking it as a builder!
