Go Back   HeliFreak > R/C Electronics Support > Airtronics Radios
Airtronics Radios Airtronics Radios Support
Old 10-17-2011, 06:29 PM   #1
Brad Collins
Default Airtronics Programming RDS 8000
How would i program for the ailerons to act as flaperons when the elevator goes up? In other words i want the ailerons to come down progressively as the elevator comes up. Im reading the manual again. If i find out, ill post in case anyone is interested in doing the same thing. Thanks
Brad
Brad Collins is offline        Reply With Quote
Old 10-18-2011, 09:55 AM   #2
LAMAR COOLEY
Default rds 8000 mixing
Brad
I have a couple of my 3D planes set up with this. I'm not at home right now and cannot remember precisely. I'll check later tonight for you. If need be. No doubt you know you have two mixing options in the advanced menu. First mixing will be to mix the flaps switch to the ailerons with the aileron as the master. Then the second mix will be elevator to flap.with the elevator as the master.
You will have to set mix numbers for proper control surface movement. The amount of flap movement you will get relative to elevator "up" will depend on the amount of "down" flap you have set. Play around with the mixing values and end point values for the movement you are looking for.
More than likely T.M. will hopefully see this and also advise you on this.
I hope this is of some small help
Regards
Team HeliProz Pilot
Here, when wanted
There, when needed
Everywhere, when looked for
LAMAR COOLEY is offline        Reply With Quote
Old 10-18-2011, 06:55 PM   #3
Brad Collins
Thanks Lamar. Still working on it. Ill let you guys know what i figure out. Im trying this on an Eflite Ultrastick. My buddy is using a spektrum radio and says my RDS8000 wont do it. I know he is dead wrong. Now to prove it.
Old 10-18-2011, 08:19 PM   #4
Brad Collins
I got it working. 1 question though. When i give up elevator the ailerons turn to flaperons and both deploy down. When i give down elevator are the flaperons supposed to go up or stay neutral? Thanks
Brad
Old 10-18-2011, 08:29 PM   #5
Brad Collins
Just so anyone who wants to know, this is how i did it:
I turned on Cmix1
Then set master to Ele
Then set SLV to Flp
Next set your percentage to whatever you like.
Next flip the switch top left next to the trainer button
Works fantastic!!!!!!!
Old 10-19-2011, 12:04 PM   #6
LAMAR COOLEY
Default rds8000 mixing
Way to go Brad. Now to "Slave / Mix" your buddy.
Regards
Team HeliProz Pilot
Here, when wanted
There, when needed
Old 10-20-2011, 06:44 AM   #7
Brad Collins
Slave mix my buddy. Ha Thats funny. Cant wait to fly this baby. I hear that it makes inverted flight much better and you can do alot more manuevers easier. Its gonna be great. Thanks for the help Lamar. You Rock!
Old 11-13-2011, 11:17 AM   #8
cstoutr
Default Brad
How are you liking that radio?
Team KBDD
Team Miniature Aircraft USA
MKS servos USA rep/ Helicommand rep
cstoutr is online now        Reply With Quote
Old 11-13-2011, 11:48 AM   #9
Brad Collins
I love Airtronics radios. A bunch of other guys started programming the mix into their planes. If i would stop buying planes and helis i could save some money and get the SD10G. Is there a better radio coming out or is the SD10G here to stay for awhile?
Brad
Old 11-13-2011, 12:45 PM   #10
cstoutr
Default I dont know
I will be keeping mine for awhile. Terry Moore would be able to tell you.
Team KBDD
Old 11-13-2011, 11:14 PM   #11
TMoore
The SD-10G is it for awhile but we're still working on future projects.
TM
TMoore is offline        Reply With Quote
