| SAB Heli Division 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support |
#101 |
Is it possible to use an Align 700MX? Will it fit?
#102 |
Tohtori A:
Tareq has flown with 4525 standards. The motor shaft can be cut If not cut the maximum height of the battery is 50 mm If you cut the maximum height is 60mm attack on an image for possible cut magnet: depends on the type of flight ... average is over 100 flights 504 Rone: in all our crashes have never broken the frame. Chuongtd: maximum motor height is 64 mm. For greater height is necessary to modify the opening in the canopy. fcveras: Align MX 700 is perfectly compatible.
Goblin Helicopters |
#103 |
Can u give us a picture of the motor with the pinion attached. I'd like to see how it is secured. For example, a standard Align pinion would have a set screw toward the bottom and therefore the majority of the tooth engagement would be above the end of the shaft. Is this the case with this pinion
#104 |
Just have a look at the posting above... the picture shows a motor with measurements where you have to place your flat spot.
The only thing I'm interested in is... 19th December, that's the date when I'll have to drive to my dealer? Next day is my birthday... will I have something to unpack? -klaus
SuziLAOS-DNHP-CenturioMax-Protos500-DJI-F550 |
#105 |
Thats great! Everytime I crash my 700e I break the frames. What kind of carbon fiber are y'all using?
NO FLYBARS |
#106 |
Post #76 2.5mm Carbon. Anything is better than the wafer board Align uses on the 700E.
"If you think you can or you can not you are right" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Goblin Xera 4530, YGE 160,VBar Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar Diablo, HJive, 4525 Ultimate,VBar |
#107 |
Hi goblinehelicopter,
I have two questions could you please help? 1- Skill level: the kit info page says "this kit is for advanced fliers only". I'm not sure if that means it cannot be set up to be smooth and docile? I'm a training pilot (forward flying, circles, stall turns) and not even close to 3D yet, can this still be "dumbed down" to fit my level? 2- Batteries: if I use 2 6S batteries in series, can they be tied one by one (separately) to the battery platform or MUST they be stuck together in a straight stick first? This affects whether i can share the 6S batts with other helis. Many thanks, GiD |
#108 |
Geek, yes and yes
#109 |
I am going to use a 4035-560 motor. Will this give you a too high head speed and if so, where can I get an 18 tooth pinion for my motor? Thanks!
#110 |
I confirm that the Goblin can put 2 separate 6S batteries.
The 18T pinion will be as an option along with spare parts.
#111 |
Any pictures of the single unit fbl support yet?
Lynx Team Pilot |
#112 | |
From the picture of motor mount, it seems that if I use HKIII-4035-560KV (I believe is one of the recommended motor), it will be mounted with 2 bolts only, as this motor uses 2x30mm 2x25mm bold spacing. Is this correct? Thanks, GiD |
#113 |
Hi,
With the motor indicated using 2 M4 screws (2 M4 x 30mm) Attack of the images flybarless support single units.
#114 |
Goddamn I can't wait fro my Goblin, all these sweet pics.
So, technical question. Any chance my Goblin can be made and delivered early, say next week?
SAB Goblin 500 SAB Goblin 700 Jeti DS-16 |
#115 |
any tech information on the goblin600. Will it be possible to fly this one on 6s, and get a nice lightweight allround heli out of it, for none 3D flying ?
Edwin
Mikado Logo500 3D FBL Low RPM long flying To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#116 |
What is the weight of the Goblin 770 just the kit and canopy, no blades or electronics nor batteries?
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once. Sponsored by : SAB USA, KONTRONIK, PRC, CANOMOD, PULSE ULTRA |
#117 |
Hi,
The Goblin 630 is a model which mechanically very similar to that of the Goblin 700 Now we are considering some possible disburdening. The Goblin 630, can save money on motor, battery, ESC. The Goblin has 630 different flying qualities. With a powerful setup is very agile (small blades) The weight of 770, for now it is 2010 grams. (Mechanical kit complete with canopy)
#118 |
So what is different on goblin 770 aside from boom length??
#119 |
Blade length.
#120 |
boom
tail belts tail pulley main shaft damper blades
