Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 10-19-2011, 07:23 PM   #1
gbidwell
Default Loose pinion grub screws
Just a heads up to X5 owners to check out your pinion for loose grub screws. I had loctited (loctite 243 blue) the grub screws in the pinion during the initial build, and after 30 -50 flights (dont really know the true number) I noticed some red dust from the main gear. Further inspection revealed that the pinion grub screws had loosened (most likley from the motor heat - expansion/contraction), causing the pinion to rock back and forawards on the shaft keys. Yyou can tell if you have this problem by holding the motor in one hand and rocking the main gear with the other whilst watching the pinion. The pinion should not move relative to the motor.
solution : applied permatex bearing mount adhesive to the shaft and pinion and then used loctite 243 on the grub screws again. 20-30 flights later, the pinion is still rock solid.
gbidwell is offline        Reply With Quote
Old 10-19-2011, 07:30 PM   #2
fusionsx00
The main gear should not rock back and fourth either.
Mine doesn't, but my original kits was bad, and empire replaced it.
fusionsx00 is offline        Reply With Quote
Old 10-19-2011, 07:38 PM   #3
gbidwell
You should have some freeplay in the main gear to pinion (mesh), otherwise the mesh is too tight and your laterally loading the main shaft and motor bearings, which will cause them to become "rough" quickly. You can't eliminate all play as the main gear is not a perfect circle and there will always be tight spots.
OR do you mean the main gear rocking in the one way beaing hub?
Old 12-15-2014, 05:06 AM   #4
isidore16
Hi,
I found this thread and it's exactly what it happened to me yesterday when I was flying my X5 for the 5th time during INVERTED FLIGHT !!
Take-off in normal mode (ESC governor 0-100% throttle curve), then switched to Idle1 (ESC governor, 70% flat throttle curve), doing some translations, loops, all was OK.
I decided to switch to idle 2 (ESC governor, 80% flat throttle curve), I heard motor speed increasing to the new throttle value.
Then I started a loop at 15 meters height, at the top of the loop (helicopter in inverted flight), all the helicopter wagged suddently and the rotor speed decreased.
Immediately I switched to throttle hold, turned over the helicopter and performed a "good" autorotation without any damage, aoutch!!!
At first I thought my BEC has failure and didn't want suply servos but on the ground I noticed some red dust from the main gear and the upper part of the main gear was stripped.
As you can see in the photo, the motor pinion grub screws had loosened causing the pinion moving up closed to the motor.
Does this issue happened to someone and how did you fix it?
I have never seen that, the two M3 pinion screws were well tightened with loctite.
IMO it's due to a lot of motor torque during acceleration from normal to idle1 mode and mostly from idle1 (70% throttle) to idle2 mode (80% throttle).
Thank's for your help.
Gaui X5 Formula, Futaba 10J, R3008SB receiver
RotorTech 515mm main blades, 85mm tail blades
Scorpion HKIII-4020 890KV, Hobbywing Platinum V3 100A
Mini VBAR, KST BLS915 HV cyclic, BLS905X HV tail
isidore16 is offline        Reply With Quote
Old 12-17-2014, 04:22 AM   #5
isidore16
I took the pinion off and I noticed that the grub screws were not well tightned or lost due to vibration.
Loctite did not worked as I expected, maybe I didn't clean enought the threads, I don't know.
I also have a question about the pinion position, How do you place your pinion (vertical position) relatively to the main gear?
The pinion is not as thick as the main gear so I placed my pinion in contact of the upper part of the main gear teeth, not centered on the gear teeth. Is it a problem?
Thank's guys
Old 12-17-2014, 11:34 AM   #6
Heli$
My pinion came loose a month ago and luckily I noticed it before flying. It was slipping up and down but would still rotate with the motor. I took the motor mount off and used a new set screw with red loctite and really tightened it down.
As far as pinion position with the main gear, I have my pinion seated as far down on my stock scorpion motor shaft as it will allow. This puts the top of the pinion aligned with the bottom of the main gear.
My main gear has been wobbly for a couple months. My OWB is pretty new and I even added an extra shim between the main gear and auto gear. It is flying just fine so I gave up on getting rid of the wobble. Maybe I'll get a new OWB this winter.
Logo 700, Gaui NX7, Gaui X5 Formula Stretch,Trex450ProDFC, all VBAR
VControl, DX9
C #773
Heli$ is offline        Reply With Quote
Old 12-17-2014, 11:39 AM   #7
Nelsonisms
I haven't inspected mine since I built the heli about a year ago, so I guess it's about time to do that. Thanks for the reminder.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote
Old 12-17-2014, 02:29 PM   #8
isidore16
Why do you place your pinion as far as possible from the motor?
If I understand you placed your pinion aligned with the bottom of the gear?
I would place the pinion centered with the main gear.
Suggestions?
Old 12-17-2014, 06:41 PM   #9
Heli$
I can't remember why I mounted the pinion flush with the bottom of the main gear. Maybe I read it in a build thread or that's what I do with my other heli that has a helical main gear and pinion.
I don't think it really matters to tell you the truth except for maybe the motor shaft won't flex as much.
Here's a pic.
VControl, DX9
C #773
Old 12-19-2014, 04:50 AM   #10
isidore16
Ok, I understand now why you mentioned you put the top of the pinion aligned with the bottom of the main gear. Your pinion is thicker than the main gear!
In my case, my main gear is thicker than my pinion so I chose to place the pinion centered with main gear teeth.
I used GAUI thread lock fo all the helicopter build including pinion grub screw.
I think it's not as good as Loctite thread lock, I'm thinking using Loctite for the pinion.
I'll see if I loose again my pinion, I'd buy loctite.
Do you use GAUI thread lock for pinion mouting?
Old 12-19-2014, 08:41 AM   #11
mverhorst
Isn't there a better pinion available? You have quite a torqy engine so you can use all the gear that you've got.
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote
Old 12-19-2014, 08:54 AM   #12
isidore16
Agree with you, I'll check for a larger pinion.
It's seems that my pinion is for X4 or something like that.
