Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-21-2011, 09:52 PM   #1
jassem3333
Default i blow up my engine
new os 91hz-r 3d engine blow up i dont know why
iwas in normal mode it was ok but when i go to idl mode 2 min and go like
E E E E E E Eeeeeeeeeeeeeeeeeee puhhhhhh
its new heli with the engine like 15 fly max when i check the temp it was 205
what is the problem ????? i dont know ... and please guys i need some tips what parts i order and hwo to do the engine its my 1st time
Tarot 450/T-rex 600 esp / T-rex 600 esp / T-rex 700 nitro / DX8
the terx 600 is my toy
my hile is t-rex 700 nitro fbl
jassem3333 is offline        Reply With Quote
Old 10-21-2011, 11:29 PM   #2
Felt
Someone else recently posted something about the same engine blowing a piston. I would be pissed after spending that kind of money.
Felt is offline        Reply With Quote
Old 10-21-2011, 11:45 PM   #3
MXRACERX43
That damage is definatley caused by a lean run. The cause of the lean run is what you need to figure out.
MXRACERX43 is offline        Reply With Quote
Old 10-22-2011, 12:58 AM   #4
jassem3333
i think i forgat the fuel stoper on the fuel line
Old 10-22-2011, 01:07 AM   #5
jassem3333
Default my engien is gone
i need some tips
http://www.helifreak.com/showthread.php?t=350327
Old 10-22-2011, 01:08 AM   #6
jassem3333
700$ +
Old 10-22-2011, 05:55 AM   #7
hakulhak
it run lean
hakulhak is offline        Reply With Quote
Old 10-22-2011, 09:14 AM   #8
dchekas
Definitely a severe lean run.
You're looking at a new piston, ring, and sleeve at a minimum.
What does the cylinder head look like?
I'd investigate and see if you can find the cause. Debris in the fuel lines/filter/carburetor? Hole in the fuel line?
Needle settings?
Team Miniature Aircraft USA
Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion
-Darrick
dchekas is offline        Reply With Quote
Old 10-22-2011, 09:30 AM   #9
whoanelly
i did the same thing in a new OS and i found a hole in the fuel line is what caused to run so lean ,,change out your fuel line.
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 10-22-2011, 09:37 AM   #10
McKrackin
Needle settings?
Missing fuel stopper...Mystery solved.
Part of the fuel went to the carb and you were crop dusting with the rest.
That means a very lean run.
Where did you check temp?
Have to check it at the glow plug.
Check it very soon and while running.
If you checked it a minute after it quit running the temp was likely way hotter than 205°
Do the best you can until you know better...Then,when you know better,do better
McKrackin is offline        Reply With Quote
Old 10-22-2011, 09:37 AM   #11
McKrackin
Left the stopper plug out of the fuel line and it went lean...Pop.
Old 10-22-2011, 09:51 AM   #12
OHIOBOWHUNTER
+1 Fuel stopper = smoking gun
OHIOBOWHUNTER is offline        Reply With Quote
