I have tried everything I can think of, but if the threaded rod goes in, it will often just strip out and spin, making no progress.
Help. Thanks. Steve
My wife is mad. I thought we were having an earthquake, so of course I grabbed the heli and headed outside..............leaving her behind. (gulp!!) |
do you push the rod into the hole hard while turning it? as it makes its own threads it can be hard. you just need to push the rod into the hole very hard while turning for the first few threads, then it should start making its own threads without you needing to push it.
t-rex 450 se v1 and t-rex 600n sport To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I ream it a little with my exacto knife first
Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Man, I have tried!! I have the most difficulty with the smallest links. It seems like when I get them both started, only one will thread, and the other just spins.
I do better with the longer links, because I can use the ball link pliers slot to grab the rod. But this is not an option with the really small ones that attach to the blade grips. Steve
Rick,
Thanks. I have tried using my pin drill to open up just the first millimeter or so, but still don't do very well. I guess it's just me, but it seems like if they just increased the rod thread depth a little it would make things a whole lot easier. Steve
#6 |
Team Taco VP
As Rick said, just bevel the entry hole a little with an Xacto knife. They do start hard as you have to make threads in them with the rod.
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
Theres a bit of a knack to it I find. You can't be soft on them! Stick the end of the Xacto in, give it a full turn (it makes a better taper angle than a drill bit) then stuff the threaded rod end in (hold it with pliers) and push whilst turning - like you're trying to screw a cuphook into a wall.
er, I presume your using the Align threaded rod and not some thicker type like bike spokes.....
450SE Silver - Power: Neu1107-2Y + 10t pinion ESC: Jazz 40-6-18 Governed. - Batts: 4s, FP 2100 Evolites. Pitch +/- 12* (TC63 PC 0,25,50,75,100), cyclic 6* HS2900 HS65Mg x3 + GY401 + S9650 tail.... Rx: AR6200 - Tx: FF9Super(T9CP) +Spektrum Module Crash count = 13 for 179. Trex time aloft = 22:42 |
#8 |
I had problems with the first one I tried, but no problems since. I do taper the hole with an Xacto knife.
I wonder if a 2mm tap would help?
FGMP |
#9 |
If it's that difficult for you, try putting the rod in the power drill first like a drill bit. Then thread the link and back out. Do that for all your links and you should be able to thread them in later with your hands. Careful not to go too deep, with that much power it can go through the link quickly if you're not careful.
#10 |
I had an extra rod. I sharpened on a sharpening stone and put it into my cordless drill. Pre-thread all my ends, then thread the real rod into it.
Jerry Moore, AMA #878954, IRCHA #2988 Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL Ok, you can fly...but can you HOVER?? To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. KISS = Keep it simple stupid (to maximize fun and reduce costs!) |
#11 | |
FGMP |
#12 |
Same ideas as me, but with a power drill, you don't even need to sharpen it. It goes in really easy.
#13 |
Yep, nice idea guys. I'll have to try that one next bird.
Rick
#14 |
I gave em all to my wife after nearly killing the dog in anger. Worked great, she handed em all back nicelt treaded 10mins later
Nano CPX, 130x, Trex250, 450Pro, 550 & 600EFL Pro. SAB Goblin 500 & 700 - Lynx Team Pilot - |
#15 |
Thanks to all for the great ideas.
Steve
#16 |
You need to hold the rod in the middle with a some fine nosed pliers, especially with the short links.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#17 |
I do the exacto knife thing but even with that it can be extremely difficult to thread. So I plan to order this one day:
http://www.readyheli.com/Heli_Max_He...p/hmxr4859.htm I bet that would make my life much easier when putting the align carbon tail rod together. |
