Old 10-30-2011, 11:06 AM   #1
helidude71
Default v3.0.8 cyclic gain (Dial 1)
With v3.0.0 dial 1 any higher then dead center would make my head oscillate.
Today I did some testing and I could almost put dial 1 into the upper corner before oscillation starts.
Anyone else noticed this change, or is it just me?
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75
TSH Gaui X5 FES, Microbeast v3, S.Bus, DS610s, DS650, YGE 100LV
Futaba T7C
Phoenix R/C v4
helidude71 is offline        Reply With Quote
Old 10-30-2011, 01:12 PM   #2
Bob O
I haven't had a chance to fly the update yet. Hopefully tomorrow or the next day.
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 10-30-2011, 01:36 PM   #3
trexpro
I never had that problem with V3.0 and now with V3.0.8 its perfect to
We Men Need a Second Hobby, Besides Women
Futaba T8FG T-Rex 550 & 450 DFC BeastX V3
Logo 600se VBar 5.3 pro Kontronik
www.modelhelicopter-review.nl
trexpro is online now        Reply With Quote
Old 10-30-2011, 02:08 PM   #4
helidude71
It's not a problem but something I noticed.
Can you crank up dial 1 much higher then before with v3.0.0?
Futaba T7C
Phoenix R/C v4
Old 10-30-2011, 02:34 PM   #5
trexpro
Was not necessary, my heli flew fine without tuning dail 1 so i left it center. Tomorrow I fly and will try it out
I'll let you know
Old 10-30-2011, 03:27 PM   #6
helidude71
Thanks!
I wish I could fly tomorrow.
When I'm back from work it's dark outside.
Futaba T7C
Phoenix R/C v4
Old 10-30-2011, 05:13 PM   #7
latte
I put on some 713 Edge blades on my 700 today, and noticed a slight wobble. A buddy at the trip thought it may be worn dampeners.
700E DFC - Vortex Compass 3Dplus - BeastX
700N FBL - BeastX 450pro 6s - 3GX
latte is offline        Reply With Quote
Old 10-31-2011, 01:14 PM   #8
trexpro
Hi helidude71,
I've experimented with dial 1 and you're right, you can indeed turn dial 1 way above center before oscillation starts. Is this good or not
Old 10-31-2011, 04:48 PM   #9
Chargersforlife
It wont oscillate in a hover, but try some real hard cyclic and collective manuevers and I bet it will oscillate.
Compass Atom 500, Beastx Hitec hs5245mg,Savox 1290mg
Chargersforlife is offline        Reply With Quote
Old 10-31-2011, 05:15 PM   #10
helidude71
Hell yes it did oscillate in a hover anything above dead center! (On my 500 bird.)
trexpro, glad you see the same thing. I thought my mind was playing with me.
Question is indeed, why?
I guess we need some time to tune dial 1 again.
Futaba T7C
Phoenix R/C v4
Old 11-01-2011, 05:37 AM   #11
regalmat
I upgraded to 3.0.8 on my Trex 500 ESP and now in IU 1 I get tail bob and in IU2 I get a hard drift to the left. In normal it is stable but the tail isn't locked in because the HS is too low.
Not sure what's going on--may change dampers and see if it makes a difference. It was flying fine before the upgrade.
regalmat is offline        Reply With Quote
Old 11-01-2011, 03:50 PM   #12
airjawed
FBL units can mask underlying problems. Something probably wasn't right before the firmware change. First thing to do is increase your headspeed according to the designs of the tail and head. Too many people are lowering the headspeeds because the FBL unit can compensate for slower roll rates by giving more cyclic...however this leads to loss of tail authority and to head vibrations and bobbing.
Is the headspeed in the manufacturer's recommendation range?
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V
airjawed is offline        Reply With Quote
Old 11-01-2011, 07:06 PM   #13
regalmat
Thanks. I'm trying out a new head speed app and will check it.
Old 11-02-2011, 05:04 PM   #14
Chargersforlife
Helidude, in your original post you said this "Today I did some testing and I could almost put dial 1 into the upper corner before oscillation starts"
Then you said "Hell yes it did oscillate in a hover anything above dead center! (On my 500 bird.)"
Old 11-03-2011, 10:58 AM   #15
helidude71
You left out an important piece of the puzzle.
If you read again my opening post, are you then still confused?
Futaba T7C
Phoenix R/C v4
Old 11-03-2011, 04:35 PM   #16
Chargersforlife
I'm not confused, you are. You must have misread my post. This isn't very confusing lol
Old 11-03-2011, 04:41 PM   #17
helidude71
I am confused. lol
Well let me refrase.
With v3.0.0 I could NOT set dial 1 any higher then dead center.
Otherwise it would oscillate.
With v3.0.8 I can set dial 1 MUCH higher and no oscillation.
Oscillation starts when it almost hits the upper corner.
Futaba T7C
Phoenix R/C v4
